Old 02-21-2012, 06:16 PM   #1
TCB Baby!
312QBUD Help Needed Desperately
Help!
Cold night coming soon...
I took her out for her maiden voyage this past weekend. Ended up filling the gray water tank so much that the tub started to overflow and will not drain.
Long story short...I pulled the gray water valve and nothing is coming out. Am I missing something or do I have a problem?
I called the dealer and they were not sure. Forest River will not return my calls. I drove all the way from Memphis to Cincinnati with a full gray tank and the mileage was ridiculous.
Any help is greatly appreciated.
Thanks,
James
jherald02 is offline   Reply With Quote
Old 02-21-2012, 06:20 PM   #2
M109Rrider's Avatar
Check to make sure you don't more than 1 grey tank. Might be another valve ,possibly even another hose connection. I'm not familiar with your unit.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 02-21-2012, 06:23 PM   #3
TCB Baby!
I believe that there is a galley tank and a gray tank but I cannot locate another pull valve anywhere under the trailer. This wasn't covered during my demo and no one at the dealer seems to know if there is a separate pull valve.
I'm really stumped. I hope it's not clogged but I can't really imagine that it is.
Old 02-21-2012, 06:35 PM   #4
M109Rrider's Avatar
If there's 2 tanks more than likely there's 2 valves. Those handles fall off from time to time, check for just a rod sticking out somewhere.
Jason and Billie
Old 02-21-2012, 06:54 PM   #5
Dave_Monica's Avatar
On your camper, is the gray water tank discharge valve visible or is it under the chassis cover connected with linkage to the T handle at the side? Is it possible that the linkage to the valve is broken or disconnected? There's usually a removable access panel where the valve are located underneath.
Dave
Old 02-21-2012, 07:31 PM   #6
On my Salem 312QBUD there are 2 gray tanks and black tank and three levers to drain.
The handle for the second gray tank is under the bunk slide. It is easiest to drain by squatting near the rear scissor jack.
buckeyefan is offline   Reply With Quote
Old 02-21-2012, 07:32 PM   #7
TCB Baby!
Dave
Thanks for chiming in Dave!
I actually have a covered heated underbelly so there isn't much to see. My valve rods are coming through the material with the handle on the end. I'm seriously considering removing the underbelly on at least one side to make sure that the handle just wasn't sealed up inside at the factory...which I've heard wouldn't be the first time. LOL.
Old 02-21-2012, 07:35 PM   #8
Also, the other gray lever is on the rail 6-9 inches above the black tank lever...
Tell us which one you are seeing and I can help guide you.
Old 02-21-2012, 07:35 PM   #9
TCB Baby!
I see that one but where is the other gray valve. The only other lever that I see is the one near the main drainage pipe. It discharges the black water. I need to find the other lever which I suspect is hiding under the underbelly.
thanks for the help!
James
Old 02-21-2012, 07:39 PM   #10
shooted's Avatar
Does the display indicate the tank is full? If it does not, it's possibly a plugged drain. Try a plunger on the drain, couldn't hurt.
shooted is offline   Reply With Quote
