Old 04-13-2016, 10:10 PM   #131
LinemanSeth's Avatar
Originally Posted by mchayes View Post
if it didn't come with a ladder and you are still on warranty, if you add the ladder yourself - you lose your warranty as we were told. so ask ask ask dealership to be sure
I had the factory put my ladder on. But the dealer said they could do it if the trailer was set up for it (blocking).
2014 Chevy 1500 Crew Cab 5.3 4X4
LinemanSeth is offline   Reply With Quote
Old 04-13-2016, 10:11 PM   #132
Sorry quoted wrong post meant to grab fab 5
Old 04-14-2016, 05:58 PM   #133
Quick question, what do you all use to hang pictures?
Zecrom is offline   Reply With Quote
Old 04-14-2016, 09:22 PM   #134
What size ball is needed for the hitch?
esloser is offline   Reply With Quote
Old 04-14-2016, 09:32 PM   #135
Brother Les's Avatar
This should help you.
https://www.etrailer.com/question-92052.html
I think I have a 2 5/8 and most very likely NOT the 2in.
Brother Les
Old 04-14-2016, 09:50 PM   #136
command has a hook that goes into the tooth style hanger on a picture and it sticks great - use for small to med. items, then you can use gorilla hooks for larger items, one tiny hole in the wall holds up to 100 pounds.
mchayes is offline   Reply With Quote
Old 04-14-2016, 10:15 PM   #137
Thanks, talked to my dealer they recommend not installing one because they said it is hard to verify if the bracing was installed.
2014 Heritage Glen 312QBUD
2015 RAM 1500 Crew Cab
Fab 5 is offline   Reply With Quote
Old 04-15-2016, 02:21 AM   #138
I go RV'ing not Camping
jgourlie's Avatar
2 5/16th ball is what you are looking for. I would suggest one with a 14,000lb capacity or larger.
The 10,000lbs capacity balls are a little to close to the max weight of the trailer for my liking.
I have the 14,000lbs equalizer ball.
Hope that helps
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 04-15-2016, 02:23 AM   #139
jgourlie's Avatar
Speaking of ladders, I am just waiting for the day my big butt pulls the ladder out of the wall. Seems rickety for how much I weigh.
Old 04-15-2016, 06:55 AM   #140
I weigh 285 and have had zero issues with the ladder
atcbrownie is offline   Reply With Quote
air conditioner, modifications, outdoor kitchen, outdoor tv, television
