Old 04-24-2016, 09:02 PM   #151
Brother Les's Avatar
Originally Posted by Zecrom View Post
OK so we just got back from our second trip with the 312. Taking it Wednesday to the dealer for warranty work. Outside speakers decided not to work, bathroom doorknob pulled off. Drawer stop fell into drawer during transport, and where awning meets trailer leaks right down onto outdoor TV mount. Going to use the warranty for what it's worth.
The leak at the awning/trailer.... is it at the 'channel splice'? Very normal/common to leak there.
Brother Les
Old 04-24-2016, 10:19 PM   #152
It may be. Didn't get up top to look but i can see a split in the LED strip under the canopy.
Zecrom is offline   Reply With Quote
Old 04-28-2016, 01:30 AM   #153
I go RV'ing not Camping
jgourlie's Avatar
Thanks goodness for the warranty
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 04-30-2016, 09:56 PM   #154
jgourlie's Avatar
Well I spent all day getting the new to me Tow rig setup with my Equalizer hitch.....I think it turned out pretty good....Sure doesn't have the power of the Tundra, but it doesn't owe me anything so I am glad to not have the payment.
Old 05-01-2016, 10:48 PM   #155
LinemanSeth's Avatar
Well my DVD player would only take the disc in halfway. Called the dealer and they said to remove the trim ring and pull the unit. There will be two screws on top with a sticker that says remove before installation. So I removed it and what do ya know the factory only removed one screw and left the other. Nothing surprises me anymore.
2014 Chevy 1500 Crew Cab 5.3 4X4
LinemanSeth is offline   Reply With Quote
Old 05-08-2016, 09:52 PM   #156
Well it seems that it doesn't matter who takes the shower we have water come out the front or back of the tub along the lip of it. Anyone else have or had this problem and any solutions?
Old 05-09-2016, 12:43 AM   #157
jgourlie's Avatar
Can you give some more details?
I am not quite understanding what is going on with your shower
Old 05-09-2016, 07:05 AM   #158
Whenever someone takes a shower, the water that is hitting the front or back wall from deflecting off the person, is running across the rim of the tub and out onto the floor. Didn't know if there were any guards or anything to put around the rim of the tub to keep the water in.
Old 05-09-2016, 09:25 AM   #159
Oops's Avatar
Ours is a 2016 & its doing the same thing. What we found is that when the tub was installed the front edge was pressed down onto the stud wall so far that it actually makes that any water that hits it or runs there from the front or back walls runs out onto the floor. It should be installed w/ a 5 degree angle back toward the shower. You can pull the screws & tilt it back however we found that when we did so the screw holes were exposed & the tub surround is too tight to get enough tilt. So Im going to let them do it under warranty. For temp use we have been very careful to make sure the curtain wraps the corner & we put a towel in the corner on the edge of the tub to keep it from running out on the wall & floor. Its a hassle but at least were camping & not waiting for a repair...
Oops is offline   Reply With Quote
Old 05-09-2016, 09:45 AM   #160
Oops's Avatar
Speaking of showers... Has anyone tried the 10 gal WH mod yet in their 312?
air conditioner, modifications, outdoor kitchen, outdoor tv, television
