Old 05-09-2016, 10:03 AM   #161
I go RV'ing not Camping
jgourlie's Avatar
Originally Posted by Zecrom View Post
Whenever someone takes a shower, the water that is hitting the front or back wall from deflecting off the person, is running across the rim of the tub and out onto the floor. Didn't know if there were any guards or anything to put around the rim of the tub to keep the water in.
I thought that was what you were meaning, but I wasn't quite sure.
I used a version of these and problem solved.
http://www.amazon.com/Magic-Shower-T...sh+guard&psc=1
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-09-2016, 10:07 AM   #162
jgourlie's Avatar
Originally Posted by Oops View Post
Speaking of showers... Has anyone tried the 10 gal WH mod yet in their 312?
I haven't run out of water having a shower yet on our 6 gallon, but I suppose once my girls get older this could be a potential problem.
The hot water on demand system that some guys are using also seems like a really good idea for our trailers as well.
This is one I will be watching closely
Old 05-09-2016, 10:18 AM   #163
That's what I was looking at for a solution but didn't know if regular tub ones would be too big. Would help with the 2 yr olds splashing too
Zecrom is offline   Reply With Quote
Old 05-09-2016, 10:27 AM   #164
jgourlie's Avatar
Truth be told they work good, I just haven't found a way to keep them attached. I have used double sided foam and automotive trim adhesive to get them to stay, but in the heat they keep coming off.
I think I might have to go with silicon or maybe pl2000 or something to fix them permanent.
Old 05-09-2016, 10:53 AM   #165
Oops's Avatar
Yep, my girls (5 of them) have really long hair & getting the shampoo conditioner etc out is challenging. They are making it work but Im considering investing in it to make it more comfortable for them. I have been looking at the inline systems but we had a 10 gal in our last camper & never ran it out. Ive got some measuring to do... If we can fit it & if I do it Ill certainly post the pics & specs.
Oops is offline   Reply With Quote
Old 05-09-2016, 07:49 PM   #166
LinemanSeth's Avatar
Haven't had the problem of running out of water yet. My wife has long think hair and we have run close. My tub on the valve side was broke behind the wall you could barely see it when on the toilet, looks as if they tightened the screw to tight. We make sure the curtain is pulled across real good till they get the new one in.
2014 Chevy 1500 Crew Cab 5.3 4X4
LinemanSeth is offline   Reply With Quote
Old 05-09-2016, 07:51 PM   #167
Name:	ImageUploadedByForest River Forums1462841447.873716.jpg
And the front panel was broken
Name:	ImageUploadedByForest River Forums1462841481.306294.jpg
Old 05-10-2016, 01:16 AM   #168
jgourlie's Avatar
Yikes
Old 05-11-2016, 12:00 PM   #169
Outside Kitchen Door
Has anyone had any troubles with the outside kitchen door?? Mine has a bow in it and will not lock properly. If so did the dealer replace it for you or what other options do I have. Click image for larger version
billyrich33 is offline   Reply With Quote
Old 05-11-2016, 12:06 PM   #170
Brother Les's Avatar
Originally Posted by billyrich33 View Post
Has anyone had any troubles with the outside kitchen door?? Mine has a bow in it and will not lock properly. If so did the dealer replace it for you or what other options do I have. Attachment 107537
I have never looked at the door 'bow', but the bottom edge did bind on one side and was out of skew. The screws holding the top/swing edge were coming out. Had to put in larger screws to hold it up.
Brother Les
air conditioner, modifications, outdoor kitchen, outdoor tv, television
