Old 05-28-2016, 05:55 PM   #181
Our first excursion for Memorial Day Weekend. We have stayed in the camper multiple times at home but this is the first real trip. Question: Does anyone have issues tripping a 30 amp service? We did it twice this morning at the campsite on shore power. We had the ac running, fridge on electric, and I'm sure the water heater was pulling in since we were doing showers. Also ran the microwave at same time. I think there should be no way everything in the trailer should be over 30 amps and tripping the breaker , otherwise it should have been wired 50 amp. I understand that breakers weaken with age but even if I'm pulling 27-28 amps that's too close to the trip limit. Input/ideas? Had no issues at home but I'm not sure I had everything loaded up at once either.
Salem312 is offline   Reply With Quote
Old 05-28-2016, 06:05 PM   #182
we have almost the same Trailer and ours is new also and we used everything at once including the 15.5 AC ,the large fridge , all lights on, plus TV to test it out and no issues. Hubby thinks you need to have the breaker checked while nice and new and maybe replaced, he also suggested checking the wiring to and from. You have a gorgeous set up and I hope all goes well. Till then, maybe don't have as much ON at once and have a Great Memorial Day Weekend.
mchayes is offline   Reply With Quote
Old 05-28-2016, 06:07 PM   #183
check that there are no wires touching each other - got that electrical tape - now is the time to use it maybe a simply fix
Old 05-28-2016, 07:47 PM   #184
Thanks for the replies. I'm sure the breaker at the campground is old and that could be the culprit. My power cord is new with the trailer. Are y'all suggesting wiring issues with the shore power, or an internal problem in my rig?
Old 05-28-2016, 10:17 PM   #185
I go RV'ing not Camping
jgourlie's Avatar
I don't think you have a wiring issue. My trailer trips if I get to much stuff going at the same time. Microwave and a/c for sure won't work same time.
I have had problems with water heater and a/c also. These trailers really should be 50 amp. The converter is a big power hog on my trailer 8-10 amps add that with a/c and I'm out of amps. Fridge on propane helps quite a bit or shut converter off while showering etc
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-28-2016, 10:50 PM   #186
I have never popped the breaker. I have blown the tongue jack fuse about 20 times though
atcbrownie is offline   Reply With Quote
Old 05-28-2016, 11:13 PM   #187
jgourlie's Avatar
I only popped the breaker a couple times on the same day. Was really hot and the a/c was going non stop, changed the breaker cause it went bad and I have been more conservative with my power usage
Old 05-28-2016, 11:14 PM   #188
jgourlie's Avatar
Why do you think that is?
Old 05-28-2016, 11:20 PM   #189
jgourlie's Avatar
I am loving the Salem colours on your rig....looks fantastic
Old 05-29-2016, 06:41 AM   #190
Thanks again for the input and comments. We are really enjoying our rig but I'm really beginning to wonder why FR didn't wire it to 50 amp. I'm am electrician by trade and have wired many homes so I understand calculating load and providing adequate service in order to prevent overload. An 1100 watt microwave will pull around 9 amps, the 15.5 btu ac around 13-15, that doesn't leave much room for the fridge, water heater, and inverter, much less a coffee pot, hair dryer, tv, etc. You should be able to run every appliance at full load at the same time at a minimum. I can understand it not handling additional appliances but can't understand it not carrying itsself. I will hook up to my new power box at home and put everything under load to see what happens, and update everyone.
air conditioner, modifications, outdoor kitchen, outdoor tv, television
