Old 06-06-2017, 10:20 AM   #381
I go RV'ing not Camping
jgourlie's Avatar
Originally Posted by Cpowers17 View Post
That's what I was afraid of having to do I wish there was a better way like the camper working like it should
If you left the bunkhouse door open it would work much better, but that isn't an option for us.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-07-2017, 01:29 PM   #382
Well this thread has been an interesting read. We bought a 2017 Heritage Glen 312QBUD last August and so far it's been great. We did have an issue with heat in the bunkhouse but the dealer removed several feet of extra duct work which seems to have greatly improved the airflow. One issue I haven't figured out is what's draining the batteries in storage. Everything is turned off and the batteries are fully charged when I put it away but even a week later they are nearly dead. I think this is causing an issue with the inverter as well. Last year I was able to plug in to be truck, flip the residential fridge on and it would begin cooking. Now it overloads the inverter and I get an E04 error message.
2016 Ford F350 Lariat
2019 Sandpiper 372 LOK
2019 Puma 32RBFQ
cstreu1026 is offline   Reply With Quote
Old 06-07-2017, 01:46 PM   #383
jgourlie's Avatar
My guess is the CO2 detector. That's usually the culprit. I always take the positive cable off the battery when I put the trailer in storage even if it's for a couple days and when I hook it back up the battery is always the same as when I left it. I have left it for a couple months this way and battery was still good to go.
One of these days I will get around to installing a dedicated battery disconnect switch so I don't have to take the battery cables off each time.
Hope that helps,
Old 06-07-2017, 02:06 PM   #384
WOuld I need to install a single disconnect or one for each battery?
Old 06-07-2017, 02:06 PM   #385
Brother Les's Avatar
There are parasite leaks that are not thought of until you have a dead battery when the camper 'sits' and is not plugged in to a land line. The CO2 detector is one and another is the radio readout. Shutting off the 'Breakers' at the converter may help on some parasites, but not all... Put a 'battery disconnect' on it or manually disconnect the battery.
Brother Les
Old 06-07-2017, 02:29 PM   #386
jgourlie's Avatar
A single should disconnect both batteries just make sure it's after the last battery connection
Old 06-07-2017, 02:34 PM   #387
With two positives and two negatives going from the batteries to the TT wouldn't i need two?
2019 Puma 32RBFQ
Old 06-07-2017, 02:37 PM   #388
jgourlie's Avatar
Just put your disconnect on the cable that goes back to the trailer. The other goes to the inverter. You just need to figure out which is which.
Or do 2 disconnects 1 on each wire that will work too
Old 06-07-2017, 02:57 PM   #389
Originally Posted by Oops View Post
2016 with inverter
On red and black is a loop that just links the batteries
The other go as seen in the pics
Attachment 135652
Attachment 135653
Attachment 135654
Attachment 135655
This is the way its wired. Wouldn't I want to kill power to the inverter too?
Old 06-07-2017, 02:59 PM   #390
jgourlie's Avatar
Ya that is probably best
Old 06-07-2017, 06:28 PM   #391
I ordered a couple of marine grade quick disconnect switches. Hopefully it's as simple as I think it will be.
2019 Puma 32RBFQ
Old 06-08-2017, 08:22 PM   #392
312qbuds bunkhouse heat
After talking with my dealer he says his normally reps on these units is to make sure the ducts are actually connected well then what he does is replaces the vent with a closable one under the stove as well as the floor register closest to the rear of the trailer (not in the bunkhouse) he told me once he did this it usually sends better airflow to the rear hope this helps my dealer Nye is supplying me with the vents needed and I will be trying this on my own.
Cpowers17 is offline   Reply With Quote
Old 06-08-2017, 08:27 PM   #393
jgourlie's Avatar
I tried that as well using tape over the vents and I ended up overheating my furnace so I gave up on that idea and just went with the electric heater.
Old 06-08-2017, 08:47 PM   #394
I put a ceramic heater with the temp set at 65 in the bunkhouse and have the camper furnace set at 68. I also set the camper fan on low to circulate the air. The kids never get cold.
atcbrownie is offline   Reply With Quote
Old 06-12-2017, 09:53 PM   #395
jgourlie's Avatar
Does anybody have any issues with the water pressure on the kitchen facet?
The rest of the rig seems pretty good, but the kitchen is barely better than a trickle. I have taken the facet apart and haven't found a restrictor. I am wondering if there might be one at the main facet connection under the sink?
Anyone faced the same?
Old 06-12-2017, 10:37 PM   #396
jgourlie's Avatar
Progressive Ems Install
Here are some pics from my Progressive Ems Install.
Old 06-13-2017, 07:23 AM   #397
Camping at Jamaica Beach RV Park in Galveston, TX. Check out the underglow LED's.
Salem312 is offline   Reply With Quote
Old 06-13-2017, 10:27 AM   #398
jgourlie's Avatar
Originally Posted by Salem312 View Post
Attachment 141222
I like those a lot. Do you have pics of the install?
Old 06-13-2017, 11:01 AM   #399
I didn't take pics along the way but can snap a few of the finished product. I modified a few things. I.e., I didn't use the connectors that came installed; those would not have stayed connected. Instead I soldered enough wire to cross the width of the trailer. Also soldered wire on power input side, ran up into the forward storage compartment. I'm pleased with how bright they are, and they're Bluetooth with multiple functions.
Old 06-17-2017, 06:03 AM   #400
Furnace
So we took our trailer out for the first time this year last night. The trouble I'm having is when I turn the furnace on it works fine but when it cuts out it will not kick in anymore. Can anyone out there help me? Unfortunately I live in northern Newfoundland and this is still a must have for the night time🙁 Also it worked fine the first two years.
billyrich33 is offline   Reply With Quote
air conditioner, modifications, outdoor kitchen, outdoor tv, television
