Old 06-13-2016, 11:52 AM   #201
Oops's Avatar
We also had a stuck sensor in the black tank. I use the black tank rinse every time I dump but there appears to be a corner it doesn't get very well. I've never had the rinse feature and it does do a lot but it appears there is no substitute for the good old pressure wand getting it all good and clean.... Well that and threatening all the daughters with replacing the TP with a wash rag haha
Oops is offline   Reply With Quote
Old 06-13-2016, 12:10 PM   #202
Brother Les's Avatar
Originally Posted by Oops View Post
Thanks, I'll look those up
SaveAJack.com
the main reason that I put these on the front are.
The side skirting hangs really low on the sides and I could not crank the scissor jack higher and it gets in the way of the skirt when fully up.
Also, the gas line runs along the door side rail on the underside and I was able to 'offset' the Sav-a Jac bracket, so the jack/plate does not touch the gas line.
Brother Les
Brother Les is online now   Reply With Quote
Old 06-13-2016, 12:16 PM   #203
We avoid putting TP in the toilet. We have a covered trash can for the TP and do not go #2. in the camper unless there is no alternative. Do you use 'RV' TP? It dissolves a lot better and hopefully will not stick to a sensor. I have 3 girls.... and they know better to NOT clog up the toilet. They can and have cleaned it out before and go well out of the way to avoid that.
Brother Les
Old 06-13-2016, 12:44 PM   #204
Oops's Avatar
We had switched to single ply regular paper due to some bad advise I guess - lesson learned we went back to the Camco paper after the stuck sensor. But yes my eldest daughter got to help me clean it out so my guess is that issue is solved as well.... We use the camper toilet exclusively and there are 7 of us so it gets a workout.
Old 06-16-2016, 01:25 AM   #205
I go RV'ing not Camping
jgourlie's Avatar
Originally Posted by Brother Les View Post
'Stabilizers' don't stabilize very well. they do not hold any weight either. I put in the front a set of 'Sav-a-Jac' brackets and added scissor jacks to the front (just behind the stabilizers). This will hold up the weight of the front and relieve some pressure weight off of the jack. Just this year I put some scissor jacks on the back.
I imagine that your trailer is pretty stable with the four scissor jacks? I have been thinking about getting jt strong arms but am second guessing with the electric stabilizers being so weak that the strongarms will have no effect.
I had read that scissor jacks were the best for stability
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-20-2016, 04:36 PM   #206
jgourlie's Avatar
So I feel like I have solved the cold bunkroom issue I was experiencing. We have started to run the a/c fan on low all night long (great white noise for the girls to stay sleeping) and then the furnace kicks in and out at it's leisure. I still have an electric heater in the bunkroom as a backup and the past few nights the bunkroom has stayed rock steady at 72 degrees.
The other side benefit is that the bunkroom or front bedroom doesn't get stuffy because the air that is getting cycled into the room from the a/c ducting.
very pleased with this turn of events for us, because before the trailer was all over the place just running on the furnace alone, either too hot or too cold.
Hope that helps,
Old 06-27-2016, 10:58 PM   #207
Well just got back from my 1500 mile trip to SC and back. Trailer did great for most part. Had a black tank issue, my fault, but had the 30amp breaker kick with just the AC and microwave running. Is this common? Do I need to look into wiring up to 50? If so has anyone done it or should I just buy the adapter and plug into 50? Any input helpful.
Zecrom is offline   Reply With Quote
Old 06-27-2016, 11:55 PM   #208
Never had my 30 amp pop. With microwave, AC, and electric smoker.
atcbrownie is offline   Reply With Quote
Old 06-28-2016, 02:12 AM   #209
jgourlie's Avatar
I was always told no microwave and a/c at the same time, or it will pop....so I have never actually tried it...just shut off a/c for a couple minutes and use microwave. I have popped my breaker using the a/c, hot water heater and both fridges on at the same time all on electric.
That was last year, I installed a hard start capacitor on my a/c this spring and it has really seemed to reduce the startup load, might be able to run a few more things at the same time now.
Old 06-28-2016, 06:45 AM   #210
I always use propane for the water heater maybe that is the difference
air conditioner, modifications, outdoor kitchen, outdoor tv, television
