Old 07-31-2016, 06:36 PM   #261
Ok qbud friends, i have dual grey water tanks and only 1 grey water drain valve. One tank is emptying and the other is not. What gives?
jwamiller is offline   Reply With Quote
Old 07-31-2016, 06:45 PM   #262
Brother Les's Avatar
Because you need to find the other gray tank drain valve handle and then you can empty the tank. My unit has one black tank and two gray tanks. The pull handle for the black tank and one gray tank are close together above the drain cap and the other gray tank valve is about four feet back, closer to the rear of the unit.
Brother Les
Old 07-31-2016, 07:04 PM   #263
All three of my drain valves are directly above the sewer drain.
atcbrownie is offline   Reply With Quote
Old 07-31-2016, 09:10 PM   #264
Bro Les, that phontom valve is not there? I wonder if they covered it up with that cheap insulation stuff? It's a 2016 model. Have used it twice. Guessing the one I have now emptied twice is for the shower, which we havent used.
Old 08-01-2016, 06:20 AM   #265
Jwamiller, I have a similar situation. First off, I know my tanks and valves are mis-labelled. My black water empties by pulling the valve labeled "waste water". It's a silver handle, long rod located directly above the drain pipe. The other 2 valves are located about a foot aft of that, they are short stubs mounted up on the frame rail. One has a black handle but is labeled "gray water" and the other has a silver handle labeled "black water". My unit is at the dealer right now for a warranty worklist, and this is one of my items on the list. I do know this: I can only get 2 showers before one tank is full. Something is not right.
Salem312 is offline   Reply With Quote
Old 08-01-2016, 08:19 AM   #266
My black water tank handle is gray.
2017 Heritage Glen 312QBUD
73JER is offline   Reply With Quote
Old 08-01-2016, 12:19 PM   #267
Finally found it friends. Its a black handle about 16" directly up from the other two. Was not expecting it to be so high up on the frame. Thank you all for your help!
Old 08-01-2016, 05:33 PM   #268
I go RV'ing not Camping
jgourlie's Avatar
Mine was also grey. Funny story as I was trying to get my grey tank to drain and I kept pulling the grey handle. I finally cut a hole in my underbelly to see why the valve wasn't opening and I quickly realized that I was draining my black tank.
So I taped the black tank handle black with electrical tape and the grey tank handle grey with duct tape so I don't get them mixed up anymore
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 08-02-2016, 12:06 PM   #269
jgourlie's Avatar
Just wanted to share my homemade 312qbud awning hold down poles.
These went through 2 thunderstorms now and work awesome.
Old 08-02-2016, 05:05 PM   #270
Jgourlie, are those the x chock xl's that you are using?
Smokeeater323 is offline   Reply With Quote
air conditioner, modifications, outdoor kitchen, outdoor tv, television
