Old 04-07-2016, 05:08 PM   #121
That's what I'd be pulling it with. I have a 2015 Silverado crew cab with trailer brake installed. It has the 5.3L. I'm in NJ.
Originally Posted by LinemanSeth View Post
I pull with a 2014 Chevy 1500 crew cab. It knows it's back there for sure. Make sure that they cover everything, even were the pump is to winterize, glad I ask on that one its in a horrible spot. My guy got to talking to much about life and went around a bunch of stuff, had to get him back on track. He ask me if I wanted to video the walk through for my reference at a Iater time. I had a Great dealer the sale part was easy and the service department seems to be really well they bent over backward for me on the stuff I ask them to fix and did a good clean job.
esloser is offline   Reply With Quote
Old 04-09-2016, 09:33 PM   #122
LinemanSeth's Avatar
Yep mine is the 5.3. I pulled it this weekend for about two hours and averaged 10.2 mpg.
2016 Ram 2500 Cummins
2017 Heritage Glen 312QBUD
LinemanSeth is offline   Reply With Quote
Old 04-11-2016, 07:22 AM   #123
Originally Posted by jgourlie View Post
Question for the fellow Qbud owners. I have noticed while towing the trailer that the drivers side fender is vibrating pretty heavily in the wind. On the passenger side there is a metal support brace connected to the frame to support the fender but on my unit on the drivers side there is nothing because the fender is part of the slide.
Has anyone else noticed the same problem?? or rather do your rigs have some kind of support??
I notice the same thing on my Wildwood. The right fender has a brace on it but the left does not. I'll probably just make one out of 1/2 X 1/8 aluminum of similar.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 04-11-2016, 04:47 PM   #124
mchayes's Avatar
adding a ladder yourself
Originally Posted by Fab 5 View Post
Has anyone added a roof ladder to their trailer? Or does anyone know if you can mount one?
2014 Heritage Glen 312QBUD
2015 RAM 1500 Crew Cab
if it didn't come with a ladder and you are still on warranty, if you add the ladder yourself - you lose your warranty as we were told. so ask ask ask dealership to be sure
mchayes is offline   Reply With Quote
Old 04-12-2016, 02:43 PM   #125
Well I was going to run the tundra for a bit but came across a great deal so now the 312s new tow vehicle will be a Chevy 3500Hd diesel. Pics to come soon
Zecrom is offline   Reply With Quote
Old 04-12-2016, 02:46 PM   #126
I go RV'ing not Camping
jgourlie's Avatar
Dang Gina!!!
That will get the job done for sure.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 04-12-2016, 02:49 PM   #127
I'm sure you'll be way happier and at ease while towing then before.
stomperz71 is offline   Reply With Quote
Old 04-12-2016, 04:19 PM   #128
I tow mine with a 2015 Chevy 3500. It tows like a champ.
atcbrownie is offline   Reply With Quote
Old 04-12-2016, 04:25 PM   #129
jgourlie's Avatar
I also got rid of my Tundra and picked up a unicorn 2000 Chev 2500 gasser with 60,000 miles on it. We will see how it tows as it's down on Horsepower from the Tundra, but it's paid for and that is what I liked most.
Old 04-12-2016, 05:34 PM   #130
Didn't really want to let the tundra go but going from 7-8 mpg to 13-14 mpg for $20 more a month, yeah easy choice.
Old 04-13-2016, 09:10 PM   #131
I had the factory put my ladder on. But the dealer said they could do it if the trailer was set up for it (blocking).
Old 04-13-2016, 09:11 PM   #132
Sorry quoted wrong post meant to grab fab 5
Old 04-14-2016, 04:58 PM   #133
Quick question, what do you all use to hang pictures?
Old 04-14-2016, 08:22 PM   #134
What size ball is needed for the hitch?
Old 04-14-2016, 08:32 PM   #135
Brother Les's Avatar
This should help you.
https://www.etrailer.com/question-92052.html
I think I have a 2 5/8 and most very likely NOT the 2in.
Brother Les
Brother Les is online now   Reply With Quote
Old 04-14-2016, 08:50 PM   #136
mchayes's Avatar
command has a hook that goes into the tooth style hanger on a picture and it sticks great - use for small to med. items, then you can use gorilla hooks for larger items, one tiny hole in the wall holds up to 100 pounds.
Old 04-14-2016, 09:15 PM   #137
Thanks, talked to my dealer they recommend not installing one because they said it is hard to verify if the bracing was installed.
Fab 5 is offline   Reply With Quote
Old 04-15-2016, 01:21 AM   #138
jgourlie's Avatar
2 5/16th ball is what you are looking for. I would suggest one with a 14,000lb capacity or larger.
The 10,000lbs capacity balls are a little to close to the max weight of the trailer for my liking.
I have the 14,000lbs equalizer ball.
Hope that helps
Old 04-15-2016, 01:23 AM   #139
jgourlie's Avatar
Speaking of ladders, I am just waiting for the day my big butt pulls the ladder out of the wall. Seems rickety for how much I weigh.
Old 04-15-2016, 05:55 AM   #140
I weigh 285 and have had zero issues with the ladder
air conditioner, modifications, outdoor kitchen, outdoor tv, television
