Old 04-14-2012, 08:47 PM   #21
When I ordered my new Ram truck, I got the 17 inch rims rather than the 20's. I figured that the extra sidewall on the tires would give a softer ride. And yes, the 20 inch tires are pricey!
The 20 inch rims sure look sharp, but I am beyond worrying about impressing the ladies!
Old 04-14-2012, 08:58 PM   #22
I wish Dodge would have stayed with the 16" rims. There is a pretty significant difference between the 16" vs the 17".
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 04-15-2012, 11:34 AM   #23
Stevea1956's Avatar
Take all those thousands of dollars you'd invest in modifying your truck and invest them in your future. Maybe you'll be able to retire sooner than you expect and can RV full time.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 04-15-2012, 12:27 PM   #24
Jasonc's Avatar
Its not that I would be investing more money modding out the truck. It is only that the truck comes with 20", and I was just wondering if 18" were better. It is not a money issue what so ever its a.ride thing.
Jasonc is offline   Reply With Quote
Old 04-15-2012, 12:32 PM   #25
My older truck was a '98 2500 Chev with 4 wheel drive. Newer one is a '06 same. The 98 was nice and low (far as getting in and out). The '06 is about 4 inches higher. Had to get the trailer axles swapped and put running boards on it. No reason for the '06 being higher other than younger people wanting higher trucks. Wayne
wayne anthony is offline   Reply With Quote
Old 04-16-2012, 10:04 PM   #26
Back to your question. I have an 2008 F-250 with 20's on it and have no problems. I did have to raise my pin box to get the nose closer to level. Have 9 in. of bed rail clearance and the trailer sits about 1 1/2 nose high. But after I put air bags in will probably raise the pin box another hole.
the.wilsons is offline   Reply With Quote
Old 04-16-2012, 10:58 PM   #27
GASPEDDLER's Avatar
I have a 2009 with the 20's and have notice no difference from other f350's I have driven over the last twenty years.....16"s 17"s. 20"s they all bounce you around like crazy.
I also got an itch to lift a truck back in 2000. Seemed like a great idea at the time but after a couple of years the thrill wore off, hard on your knees too climbing in and out. But hell you live once, get it out of your system.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 05-06-2012, 06:15 PM   #28
tdeal823's Avatar
I know this is a Chevy but i think this is the look of what you are going for? Biggest wheel and tire combo to get a good all terrain look.
2008 2500HD tuned, Deleted, Removed, Blocked, and leveled with air bags in the rear
2011 Sabre 32BHOK
Your sabre will aready come with the "axle flip" Sabres are that was from the factory. Plus all the lift you add will also add to your over all trailer height. I don't know your specific trailer height but mine was 12'8" from the factory i am now at about 13' even.
https://lh6.googleusercontent.com/-0...-15-03_289.jpg
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion or Pullrite 24K, riderite 5000 airbags
2011 Sabre 32BHOK-6 most of the options
tdeal823 is offline   Reply With Quote
f350
