Old 04-14-2012, 11:24 AM   #1
Jasonc's Avatar
4" Lift kit on F350
Hi, I just ordered a 2012 F350. I would like to put a 4" lift kit on the truck....however what is the maximum height I can put the truck to before it won't work with my new 2013 Sabre 365qbok.
Jasonc is offline   Reply With Quote
Old 04-14-2012, 11:36 AM   #2
0 lift, and I mean ZERO. No lifted truck is going to tow correctly. Getting a hitch to drop enough to keep the trailer level while towing, will be a nightmare, and may have to be a custom job. While you will have enough truck to pull the trailer safely, the lift will make it unsafe. Now my opinion, and my experience helping those that have tried. Your mileage may vary, as always.
Also since it looks like a new truck is on the way, you will need to drive 500 miles or more before towing, (check the owner's manual). You will also void any and all warranty with a lift kit, and I am assuming the warranty is 3 years and 36,000 miles.
If it were mine, I would wait a while on the lift kit.
By the way, Welcome to the forums.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-14-2012, 12:12 PM   #3
The new trucks are so tall already, that I have to agree with windrider, no lift is a good idea.
Why do you want a lift kit?
Old 04-14-2012, 12:28 PM   #4
Jasonc's Avatar
Not sure why to be honest....just trying to look younger than I am perhaps....
It wasn't a definite plan I had made, just a thought that past through my head this morning when some young punk had a bigger truck than me lol, rather stupid I know.
But now that I hear it is a bad plan, I will follow your advice.
Than you
Old 04-14-2012, 12:47 PM   #5
Coops1's Avatar
Go with a leveling kit like Cognito, it will give you the stance you want and not compromise your ride and towing.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 04-14-2012, 12:58 PM   #6
I tow with a 2008 Dodge 3/4 ton with a 2" leveling kit and 35" tall tires (315/70-17). I have no issues at all with my set up. It sits much higher than a bone stock truck so to say you can't tow with any lift at all is a pretty broad statement. My current travel trailer and my previous travel trailer pulled just fine. A fiver may run into issues with clearance on your bed rails.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 04-14-2012, 01:58 PM   #7
I have a 4in lift in the 99 f250 SD, I tow a work trailer every day, but its a tag. I used to tow a cougar 5er with it, i cant tell you how many times i hit the rear of the bed on the underside of the trailer. Stability is compromised and if you have a blow out the truck drops like 10 inches because of the big tires. If you wanna be all badd a@@ and jack it to Jesus, put air bags in it and run it low to tow...AIR BAG IT.com
1999-2011 F&R FORD F250/F350/EXCURSION with 2wd Independent, Single Rear Wheel 3.5" Rear Axle 4" up 4" down, 8" travel, replaces Factory Coil springs, Complete with Plug & PlayShip Raw unless upgraded to Powdercoat
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 04-14-2012, 02:25 PM   #8
prof_fate's Avatar
There are several ways to lift a truck, but all will raise the center of gravity and 99% of the ones I've seen also include bigger wheels/tires.
When you put on bigger wheels/tires you change gearing and increase the load on the brakes (longer arm moment) as well. This will change your towing and GCWR figures - how much is only a guess unless you have the resources of Ford or GM.
So things will be closer to their design limit, if not over it. This may be unsafe (or not) but it certainly will impact the lifespan/maintenance of many components.
And every lifted vehicle I know takes a hit in MPG, so I can't imagine what adding 4 or 5 ton trailer would do to that.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-14-2012, 02:54 PM   #9
Twisty's Avatar
Dude - Get over it!
I just put an Amp Research bed step on my truck. I already put Rampage Stirrup Steps on it.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 04-14-2012, 04:57 PM   #10
Dave_Monica's Avatar
I'll bet that you have a tough time getting 6" of clearance between the camper on the truck with the truck at stock height and the camper level. Forget the lift kit.
Dave
f350
