Old 09-06-2015, 10:36 PM   #31
Left Coast
Originally Posted by Ditchdigger View Post
I have FR Wolf Pack I spent the winter 5200' in Philipsburg, MT. two years ago(I won't do it again if I can help it) I found that anything under 22 deg. you are going to lose your water( I don't know if my tanks are heated or not) at 36" below you will have ice in the sink with the heater running full bore. The trailer is good to about 20-22 deg. I go south now to AZ.
What were you think'n?
Old 09-07-2015, 03:54 AM   #32
Witch Doctor's Avatar
Your a smart man, FR doesn't make a true 4 season trailer nor will they ever. If someone is looking for a 4 season trailer they better start looking at Arctic Fox or something. 2"walls can't hold enough installation. If you look at the spec sheets and construction it's plain to see why. They have tried that spray on foam that just falls off and half the water pipes where missed along the edge. At least of the one I saw.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-07-2015, 09:01 AM   #33
Originally Posted by gljurczyk View Post
I have a register in the sidewall of the belly that is connected to a 2" duct. Also the heat tape is located at the three vales, so they will not freeze. FR doesn't do anything the same. They come on when I put the tank heaters on.You can even see the tape wrapped on my gray water from the galley the rest are in the belly..
I think you are right about FR not doing anything the same! Seems like no two trailers leave there equipped the same, LO! The heat tape around the valves might be a good idea even though they shouldn't freeze because water would only be there when we are empting a tank. The only one I think I might need is on the gallery drain line. If most of the drain is in the underbelly I might not need it there, got to look at it.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 09-07-2015, 09:16 AM   #34
Originally Posted by bob caldwell View Post
2010 Rockwood 8280 (rear kitchen) has water pump in bottom cabinet next to fridge inside. Also has dedicated 4" furnace duct into pass-thru. Has heated tanks, but not protection on dump pipes or valves.
I wish my pump was inside of a cabinet like yours. Mine is located in the pass thru storage area. The piping comes straight up from the FW tank to the pump, then up next to the bedroom floor. Then goes across to the bathroom sink and outside shower. From the sink it goes towards the back into the shower stall.
Don't think a tape is really needed on the valves but might be nice on the drain pipe, depending on how much of it is exposed.
Jim
George Bernard Shaw
Old 09-07-2015, 09:22 AM   #35
Will be interesting to hear about those going to Alaska and how they adapt to unknown conditions....power/cold/tires/fuel.......money spent in prep, and trip.
I agree, it would be interesting. Want to know what works and what doesn't.
Jim
George Bernard Shaw
Old 09-07-2015, 05:19 PM   #36
My truck kept breaking down and left me stranded in Philipsburg, MT. I was trying to go south. Have a newer truck now. OH P.S. My pump did freeze up but it did not hurt it, it broke the water filter, and my toilet valve.
Ditchdigger is offline   Reply With Quote
Old 09-07-2015, 05:26 PM   #37
Left Coast
Like going to bed and gett'n up in morn to find it snowed during night....not like that makes noise! I had a regulator go bad that night....had to warm up in truck....lucky nothing but me froze.
Old 09-07-2015, 05:55 PM   #38
Just a member
kandl's Avatar
Originally Posted by prairiecamper View Post
Bring it out here where we have real winter, the fourth season, and then let me know how it works out.
Fourth season??? Can't be! There's only two seasons on the prairies!
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 09-07-2015, 07:25 PM   #39
Jim
The only thing that keeps the water staying in is the valve itself, so water could freeze the valve being it having constant water from gray or black against it. I would think it is standard on any heated tank option. But you know FR. NEVER the same....
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-07-2015, 07:39 PM   #40
Left Coast
Noth'n say'n the pump has to stay there.
5er, winter
