09-04-2015, 03:01 PM
5er winter & cold weather use
I just got off the telephone with Forest River. I was speaking to one of their techs about using the trailer in cold weather. I asked him if there was a register in the underbelly of the trailer and he told me no. According to him the only heat supply to the underbelly is from the flex duct work which is not insulated and they protect all the tanks with the heat pads, all four of them. I asked what protected the water pump and he told me he has never heard of the water pump freezing up. I questioned him twice about this but he insisted that he never had heard of one freezing.
I also asked about using a heat tape around the pipes and pomp and he told me that shouldn't damage them in any way by doing that.
I asked what temperature range the trailer is insulated to but he could not answer that. He informed me that FR claims their trailers to be three sason trailers, not four, but he does know owners have used them thru the winter with-out any problems. He told me the ceeiling is inulated with 4 to 4 1/2 inches of foam, the floor has 2 inches of fiberglass insulation and the walls have 1 1/2 inches of fiberglass in them.
That is not a lot but with good heaters it should work down to around 20 degrees I think. At least I hope so. If it gets below that I will plan on staying home. I would like to be able to use it a little below freezing though.
From what he is telling me I shouldn't need any air blowing into the underbelly but to be safe I think I will us a 4 inch booster fan blowing down thr. It sure can't hurt! Debating between blowing air around the pump and plumbing in that area and using the heat tapes. Not sure which would be better. I could also just put a small electric heater next to the water pump. I have one that is controlled by a stat I could use.
As always this is open to suggestions and thoughts.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
09-04-2015, 10:10 PM
Even with 93° temps today (middle TN) it's probably not too early in the season to talk about frozen water pipes on the trailer. I've got the same thoughts with plans to camp thru December in Tennessee. Don't have heat tape on the tanks yet, but probably won't use the fresh tank and water pump as both of our destinations have pedistal water. However, I did find an electric water hose at Camping World so I won't need to unhook water hose at night, a habit I started when other rigs froze around me.
As for heating the basement I'll use an old Polonis thermostat controlled mini space heater adjusted to 60ish degrees. The gas furnace blows a small amount of heat into the basement of the 5th wheel which we only use at night below 30 degrees. My knowledgeable dealer says not to worry about water pipes under the enclosed trailer down to 25, just use the gas furnace periodically.
DW mentioned than hot water pipes actually seemed to warm up the cold water this past summer and an inspection shows that they both touch each other through most of the basement routing. So simply using hot water at our rear kitchen faucet before nap time should help keep them (pipes) flowing.
Another forum member suggested an oil filled 1500 watt space heater inside the coach, have not made that commitment yet.
Rob
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
09-04-2015, 10:44 PM
FR has never made/sold a 4-season trailer.
that's why you didn't get the answers you wanted.
if you wanted something that was constructed for very cold temps, you should have looked at Arctic Fox or Outdoors RV.
there are other manufacturers that make 4-season trailers also. but not FR.
09-04-2015, 11:37 PM
Always Learning
I have had a Forest River rep tell me with a wink and a smile that these campers are really 2 1/2-season use.
Mine is OK down to 30-degree nights as long as it warms up the next day. Much colder than that and I'm the problem, not it!
09-05-2015, 08:03 AM
First off, times 2 on what bikendan posted.
So let’s clarify who you talked to. You say you talked to a Forest River tech. Was it someone at corporate Forest River, or a tech at a specific RV brand, or a dealership tech that works on Forest River RVs?
Forest River makes a lot of different brands of RVs that range from entry level with an open underbelly and poor insulation to higher end Cedar Creeks and Cardinals with enclosed underbellies and good insulation. What Forest River brand were you talking about or was it one of FR subsidiaries, Coachmen, Palomino, Prime Time, or Shasta?
I have owned two Wildcat RVs and now I have a CC Silverback and have never had an issue with a water pump freezing up since all three fifth wheels dumped air from the furnace into the front storage compartment. We have camped many times with temps in the low 20’s.
When temps are 32 degrees and above I use a space heater to supplement the furnace. When temps are down into the 20s I turn on the tank heaters and only run the furnace so that warm air is dumped from the furnace to the front storage compartment at frequent intervals. Yes I use a lot of propane but I’ve never sustained damage due to cold weather.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
09-05-2015, 08:43 AM
I'm not sure what model you have and what options but no FR trailers are 4 season. Was the tech an employee at corporate, assembly line, or a dealer employee?
They do pretty well for 3 season when equipped correctly. Sealed underbelly and tank heaters. I've been camping in March in Utah with mine with no problem. I have a couple duck hunting trips in October November. After that I'll put her up for the winter. I'm expecting freezing temps at night but 40s in the day.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
09-05-2015, 08:54 AM
Oakman,
When I say I spoke with a FR tech it is a tech from Forest River the Rockwood Signature Ultra-lite division, phone number 574 642-2640. I go straight to the horses mouth when ever possible. My trailer is an 08
Rockwood Signature Ultra-lite. I know FR makes many models and probably over half of the 5ers on the road.
I have been told by some members that there is a 2" register in the sealed underbelly but according to the tech that is not the case, at least not with the Rockwood models. He says the heating pads on the tanks and the heat from the uninsulated flex duct work is enough to keep the tanks from freezing. There is also a 4" flex duct that runs across the trailer near the pump and exposed pipes. Probably supplies enough heat to the storage area but?
I plan on installing two 4" booster fans, one to the underbelly and one to blow on the pump area. Both will be on a thermostat set around 40 to 50 degrees.
To heat the trailer I plan on using a good ceramic heater set about 70' and then set the furnace thermostat to around 65' for nights that the electric heater can't keep up.
Jim
George Bernard Shaw
09-05-2015, 09:01 AM
I survived last winter in Kentucky with temperatures down in the teens with just two electric heaters, occasional gas heat. I do have the heat traced water hose also.
2015 Siera 377FLIK
2014 Ford F350 KR
Maggie the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
09-05-2015, 09:06 AM
I don't plan on living in my 5er but want to be able to use it when it gets cold, say 30 to 40 degrees, but want to be safe if it gets colder than that.
I have never seen a 4 season 5er in the area I live in which is NJ. I am sure they are out there but I have never seen one.
Want to be able to go to SC in the winter and want the trailer to be safe, it can get into the 20's on occasion.
Jim
George Bernard Shaw
09-05-2015, 09:12 AM
The Rockwood has a s ealed underbelly and tank heaters.
Jim
George Bernard Shaw
09-05-2015, 10:50 AM
I think you should be just fine then.
09-05-2015, 11:26 AM
Left Coast
My 2010 Rockwood does have a heat duck in the pass-thru....only problem was when the under-belly was installed, 2 of the ducts were torn in half....so after I replaced them, all's well. Have camped in 20 degree weather, and use an oil filled heater..works ok for me. Only problem, was leaving awning out.....pivot points froze and had to thaw 'em out to retract. Will be addressing hose to pedestal soon.....
09-05-2015, 12:36 PM
Good timing as we are driving into Yellowstone as we speak and temps expected into the high 20s we have a Work n Play 34.5 and do not have an enclosed underbelly....we have a heated hose, and plan on keeping about a cup of RV antifreeze in the grey and black tanks....we will keep our furnace set at 60 and use a little buddy propane inside at night....hopefully this will be OK! Any thoughts?
09-05-2015, 12:42 PM
Left Coast
Depends on what day time temps warm up to.....can't really say that having an enclosed underbelly does a lot....cold is cold! Faucet slightly on would help...some places ask you to disconnect hoses at night.
09-05-2015, 01:25 PM
dgibbs1955
I have lived in my FR XLR Viper for the last 3 winters. I made all my mistakes in the first one and have had no problems since then. I use a heated water hose that is contained in 1 inch pipe insulation (from Lowe's), that is plugged into my shore power station. I let the farthest faucet just trickle both cold and hot water to keep the water moving through the night. If not, then it will stop at the master bath and not reach the kitchen faucet. I put a reflective flood lamp in the basement area to keep the water closet space above freezing. I use 2 ceramic space heaters set on low, so as to not over load the circuit, and the thermostat set on 68. In the bedroom area I use another space heater and electric blanket. It is important to keep that water moving at night, or you will have no water in the morning. This is what worked best for the open plains of Oklahoma during the winter. I am pretty sure it would work everywhere else also. Best of luck....
2012 Dodge 3500 Cummins Crew Cab 4X4, "Decluttered" and Tuned/2020 Riverstone 39RKFB/2012 Harley Davidson Ultra Glide CVO.
Summer in Blair,Nebraska.
Winter at home in Azle, TX.
09-05-2015, 03:08 PM
Hâve 2016 prime Time spartan 1234x ondulation is R-50 cargo And all tank have heating pads plus hot air blowing under double thermos panes Windows think i could survived cold weather also have sticker on it says extreme weather package
09-05-2015, 07:31 PM
Our last trip out last November it dropped to about 14F overnight. We had the oil filled heater on the Sunseeker circuit and a small ceramic heater on a cord snaked under the slide plugged into the pedestal. I had the AC fan running to circulate the warm air and the furnace set to 60F. Bundled under my wife's quilts and slept well. I did disconnect and stow the water hose and ran the internal water system. Wife was bummed out that I had a hot shower in the rig and she did not because the bath house pipes were frozen...
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
09-05-2015, 07:44 PM
Low for tonight is supposed to be near 32F here in Cascade, furnace will be running I'm sure so not to worried.
Sealed belly and all doors closed.
09-05-2015, 08:03 PM
Originally Posted by oldtool2
Oakman,
Jim
Well that teck is as wrong as can be. I have Rockwood and I have 2" duct to the belly, I also have heated tanks and my discharge lines have heat tape on them that is activated when needed. In the cold extended times I put a 1500 watt heater in the basement and run the plug to the 20 amp socket on the pedestal. I don't know who you talked to or if they changed something but this is what I have. All I do is fill my FW tank and store the hose in the belly. Never had a problem yet, but they are all 3 seasons....
Coachmen M/H
Concord
2018 / 300 DSC
09-05-2015, 09:03 PM
This is a great thread topic, and the timing is excellent since cooler weather is just around the corner.
This winter will be our first with the Silverback, and I've already been thinking about that water pump in the basement. There is a 120 volt AC receptacle right above and behind the pump. I'm thinking of mounting two incandescent light bulb sockets next to the pump and wire a switch to them and pick up power at the socket. Two 40 watt light bulbs should provide adequate heat to prevent the pump from freezing. The reason for 2 bulbs is in case one burns out during the night.
When the camper is parked at home, I keep a small ceramic heater set at 45 deg +/- centrally located in the coach. I'm in Louisiana, so we rarely see a nighttime temp below 25.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
