Old 07-20-2015, 01:38 PM   #1
mikkeeh's Avatar
5th Wheel landing gear spring pins
When hooking up and retracting my hydraulic landing gear.....I always seem to have a wrestling match trying to hold the pin back with one hand....and lifting the landing gear leg with the other. I also have JT Strongarms, which probably contribute a little to the problem.
Does anyone use a spring pin that locks in the open position??
mikkeeh is offline   Reply With Quote
Old 07-20-2015, 01:52 PM   #2
clr
Every spring pin that I have seen the spring forces the pin in (or the closed) position. Also my hydraulic landing gear does not use any pins and again I suppose I have never seen any hydraulic landing gear that does. But if you say your landing jacks are hydraulic and have pins it must be so and a fault in my experience.
clr is offline   Reply With Quote
Old 07-20-2015, 01:59 PM   #3
mikkeeh's Avatar
They are designed so that you manually lower the foot plate close to the ground....release and lock the pin......then lift the load with the hydraulic system.
Not sure Ive seen a system that didn't have them.
Hmmm
Old 07-20-2015, 02:00 PM   #4
TURBS's Avatar
Dry graphite on the legs!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-20-2015, 03:11 PM   #5
Fulltime family RVer
Switch to SteadyFast stabilizers and the legs are so much easier to raise! I was really shocked at the night and day difference.
But generally speaking- I haven't had much of the issue that you refer to; I have been able to hold the pin out with one hand and lift with the other. I do regularly spray my legs with dry silicone/graphic to keep them lubed.
Old 07-20-2015, 04:04 PM   #6
mikkeeh's Avatar
Maybe I need to dis assemble and clean/ lube.
Old 07-24-2015, 09:53 AM   #7
Dust
Watch putting spray lube on stabilizer legs. If you get into a dusty area, the dirt will cling to anything with grease or oil on it. Could end up with a mess, that will not work very well.
Dug2013 is offline   Reply With Quote
Old 07-24-2015, 09:59 AM   #8
Are you referring to the aftermarket spring loaded pins that replace the factory pin with the wire swing over lock? I thought they locked into the open position if you twist the handle 90 degrees.
5th wheel, wheel
