Old 09-01-2014, 05:00 PM   #1
5th wheel questions from boingram
Hi all...we have been tt owners and are used to using the bed of our tv for our toys. Starting to consider purchase of a 30 to 32 footer. Not that familiar with fiver hookup...we can put our kayaks on the roof but my 10hp four stroke motor is our issue. Cannot lay it down and it stands abt as tall as the tv roof...what do do and is this a problem...thx...bo
boingram is offline   Reply With Quote
Old 09-01-2014, 05:02 PM   #2
...addendum...we will put the kayaks on the roof of the tv...bo
Old 09-01-2014, 08:46 PM   #3
Campin Cajun's Avatar
I'm a little confused about your question. What do you mean by the 10hp engine is as tall as the tow vehicle? And why can't you lay it down? I am assuming you mean the engine.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-01-2014, 09:15 PM   #4
SKnight's Avatar
Four strokes carry their oil in crankcase instead of in the fuel like a two stroke, if you lay them down then oil could get into the cylinders causing a hydrolock condition and oil getting into the water.
As for carrying it, depends on a few factors. How long is your bed? What type hitch are you considering?
I've got a short bed truck and I'm carrying an EX4500 generator that is considerably taller than the bed and extends back a couple of feet. In general, it's not been an issue. However, I can't do a 90* turn anymore.
If you built a device that allowed you to stand it up in the center of the bed up front then you could get away with most of your turning radius.
Old 09-02-2014, 06:28 AM   #5
MarcusN's Avatar
If you get one of the Rockwood/Flagstaff Ultra Lites they have the revolution pin box and you should be able to stand the motor up in the center and have no clearance problems as the 5er rotates 22" back from the pin and on mine I clear bikes and other stuff with just about a 90 degree turn no problem. They all are 32' or shorter.
Mark & Barb
2013 8289WS Platinum Pkg
2008 F350 King Ranch CC 6.4
2013 nights camped 35
MarcusN is offline   Reply With Quote
Old 09-02-2014, 06:38 AM   #6
Salt Shaker's Avatar
I would build a bracket and hang it off the 5er rear bumper. Same with the yaks. Stand them up and stap them in.
What kind of kayak you running that takes a 10 hp 4stroke?
You not going to want to lug that around alot no matter where you put it.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 09-02-2014, 06:54 AM   #7
kerrlakelover's Avatar
Salt
Careful about what you do with/on the back bumper. There's LOTS of discussion on the forum about issues with back bumpers. If you really want to be safe, look for a FW that comes with, or has the option for, a carrying rack on the back. (Even these do not have very high load ratings.) I would advise you to do a search on back bumper on the forum and read about the subject. If you don't get a factory installed rack you can also run into warranty issues and bumper/frame structural issues.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 09-02-2014, 07:04 AM   #8
Taranwanderer's Avatar
Sounds like you need a toy hauler 5-er. Build a bracket and strap it down in the garage.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-02-2014, 07:32 AM   #9
Hi,
I would look carefully at the owner's material for your motor, for information about horizontal transport.
Every four stroke I've ever owned or handled could be laid down on one specific side without creating the problem you described. On the Hondas and Nissans that I own -- and regularly carry on their side in my truck -- there actually are little tabs on that side of the motor, which hold it nice and level.
Hope this helps.
Rich Phillips
richp is online now   Reply With Quote
Old 09-09-2014, 07:23 PM   #10
mlhawke's Avatar
Name:	ImageUploadedByForest River Forums1410308540.211758.jpg
Here is an idea I found at the local Love's gas station. We are thinking about doing the same. Good luck.
The Hawke's have landed!
mlhawke is offline   Reply With Quote
5th wheel, wheel
