Old 05-28-2015, 03:57 PM   #11
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by frozen View Post
Even the best, properly inflated tires will heat up and fail if they're running on misaligned axles as I've experienced first hand. Not just tires, but bearings are at risk. Without verifying alignment at a truck/trailer shop, tire replacement might be an expensive exercise in futility leading to more premature failures.
BINGO! Best advice for anyone experiencing consecutive blow-outs.
05CrewDually is offline   Reply With Quote
Old 05-29-2015, 09:05 PM   #12
Big earl's Avatar
I replaced mine with BF Goodrich Commercial T/A. About 1000.00 for five. I've got 2013 34' Sandpiper loaded weight about 10400 lbs fifth wheel
Big earl is offline   Reply With Quote
Old 06-01-2015, 05:47 PM   #13
The Maxxis are great tires. I had e rated tires on my sandpiper 365saq.
I switched out to goodyear g614.
They have a heavier load capacity per tire and are a much better tire than what's on the market. In my opinion.
They are a small semi truck tire.
By going up in capacity I think you will notice a big difference.
Just my 2 cent!!
I hate tire problems and damage to an Rv from them
chiro is offline   Reply With Quote
5th wheel, replacement, tire, wheel
