Old 05-26-2015, 12:38 PM   #1
Ready to Go
JeffLynn's Avatar
5th Wheel tire replacement
Hello fellow campers.
In two separate trips I have blown 2 tires (current Good Year) with less than 7k miles and inflated to 74lbs. Between the two it caused over $6k in damage to my 2013 Sanibel RV. I am looking at the Michelin replacing all 4 and my spare tire too. Make some noise and let me know what you all think.
Current RV Tire information
ST235/80R16 GoodYear Marathon
Load Range - E
Max Single 1550
Max double 1360
Cold 80 PSI
Looking at these
Michelin LTX M/S2
LT265/75R16
Load Range - E
Max Single 3415
Max double 3085
Cold 80 PSI
The Lessmiller's
2001 F250 SD 7.3 Turbo
2013 Sanibel 39' 5th wheel.
JeffLynn is offline   Reply With Quote
Old 05-26-2015, 12:48 PM   #2
The Goodyear is rated at 3420 lbs. So the Michelin is under by 5 lbs which if your not at max weight should not be a big deal. Can I ask why you are not running the Goodyear's at 80 psi. St tires should be run at the maximum on the sidewall.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-26-2015, 12:48 PM   #3
hrlyguy2's Avatar
Had the same thing happened to me .But trail express tires.
I put Michelin xps ribs 235 85 16 and did alot of research. Went with these tires because I didn't want to change rims out
I run 80 psi in all my tires
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 05-26-2015, 02:03 PM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
Do you monitor?
Amazon.com: TireTech On TP7002 Wireless Tire Pressure Monitoring System w/ 6 Brass Transmitters 0-232 psi: Automotive
donanddona is offline   Reply With Quote
Old 05-27-2015, 12:58 PM   #5
look at the Maxis 8008 . Great tire , decent price , pulls great
Spike
"old hot rodder"
2011 Ram3500 6.7
2012 40' Sanibel
Speed limit 65 , Fords & Chevys , do your best
47chevy is offline   Reply With Quote
Old 05-27-2015, 01:35 PM   #6
DDC
DDC's Avatar
The biggest cause of trailer tire blowouts is under inflation, and reading the OP he was running under inflated tires, I wonder why though, was this advice given by someone.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-27-2015, 06:27 PM   #7
Have run Goodyear Marathons on a travel trailer and a fifth wheel with no issue. What speed are you traveling. ST tires are rated for 65 mph.
lazyjj is offline   Reply With Quote
Old 05-27-2015, 08:15 PM   #8
Tire issues
In 7k you have blown up 2 tires and have all that damage? I know there are tires stories all over the net, but you need to ask yourself some very important questions first;
1) What is your travel speed
2) What air pressure are you running
3) and probably the most important, What is your weight loaded
You need to look at these 3 things very closely or no matter what tire you put on your coach it will keep blowing up, You have to keep your speed under 65 mph, you have to make sure your tires are aired up EVERY day you want to travel, and you must be under weight for the tires, or they will over heat and blow up.
I hope this info helps and if you need more feel free to contact me or this forum again.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 05-28-2015, 02:39 AM   #9
Load Range - E
Max Single 1550
Max double 1360
Cold 80 PSI
Looking at these
Michelin LTX M/S2
LT265/75R16
Load Range - E
Max Single 3415
Max double 3085
Cold 80 PSI
I think you will find that the LT245/75R16 is a closer size match to your OEM size. I almost replaced my OEM Akurets with these Michelin, but the Max Cap was little lower and also I felt more comfortable with ST tire design over the LT for my 5ver.
After a number a recommendations...I went with the Carlisle RADIAL TRAIL RH ST 235/80R16. Our local Discount Tire store had them in stock for $625 mounted and balanced (Yes I always balance my RV tires), but our RV dealer actually had them for ~100 less so I got them there. Good luck with your decision.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 05-28-2015, 11:56 AM   #10
frozen's Avatar
Even the best, properly inflated tires will heat up and fail if they're running on misaligned axles as I've experienced first hand. Not just tires, but bearings are at risk. Without verifying alignment at a truck/trailer shop, tire replacement might be an expensive exercise in futility leading to more premature failures.
frozen is offline   Reply With Quote
5th wheel, replacement, tire, wheel
