Old 07-17-2012, 07:54 PM   #1
A/c
I am new to this but I am looking to replace my a/c in 26ft fifth wheel. What size, brand and ducted or not? The one i have now is not doing the job. Thanks for the help
Cottonman is offline   Reply With Quote
Old 07-17-2012, 07:59 PM   #2
TURBS's Avatar
15k would be great.
Is your camper currently ducted?
If not then a ducted won't work for you without a lot of work.
I have one 13.5 k in the humid hot Midwest on a 34' 5th wheel and I think it does the job and no more.
I am ducted.
Shade always helps!
Old 07-17-2012, 08:04 PM   #3
My is ducted. The unit I have now is bout 10 years old. How Long do they last?
Old 07-17-2012, 08:26 PM   #4
TURBS's Avatar
Lol till they quit!
Is it a 13.5 k?
You could up to a 15k ducted.
A good local roof top a/c man might help you decide if yours is working properly. Could be something simple.
Old 07-17-2012, 08:40 PM   #5
I think it is a 13.5k and it just not cooling the camper thanks for your input
Old 07-17-2012, 08:46 PM   #6
Dave_Monica's Avatar
If it's physically working but not blowing cold air, it may just need recharging. It's not too expensive to recharge.
Dave
Old 07-17-2012, 08:50 PM   #7
VinceU's Avatar
Suggest taking the current unit specs to your favorite supplier and compare footprint, duct sizes, thermostat wiring etc to newer units. Could be Dometic, Coleman or others. If you you can match the dimensions and still increase capacity great. If new thermo wiring is 4 wire and you have 3, or power supply requires the next size, sure increases the install activity/costs.
Old 07-18-2012, 09:33 AM   #8
Thanks I will looking into it
Old 07-18-2012, 10:25 AM   #9
Another suggestion...
Take a temperature on the air blowing out right at the A/C unit outlet (quick cool). I believe that you're looking for a temperature around 65 F.
That would be good info when talking to a A/C tech.
Dave
Old 07-18-2012, 10:44 AM   #10
Also might want to check the fins on top to make sure they are clean and that the filter is clean. Neighbor had one that was 18yr old and had never cleaned it. Once they took care of the fins (lots of muddaubbers) and cleaned the filter it worked great
jmswms is offline   Reply With Quote
