04-22-2019, 11:07 AM
DaveAlb
Adding Towel Bars
Has anyone come up with a good way to add towel bars to their camper of any kind?
04-22-2019, 11:16 AM
We use a stainless steel rack with towel hooks that hangs on the top of the bathroom door.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
04-22-2019, 11:18 AM
I added a screen door bar and hang towels over it. https://www.campingworld.com/screen-...SABEgLMF_D_BwE
I also use bungee cords. I have yet to put up the towel bar provided by FR.
2019 Flagstaff E-Pro 14FK
04-22-2019, 11:20 AM
I hung 2 towel bars on the inside of the door. You can't be an animal with them but 7 years so far.
04-22-2019, 11:23 AM
We went a similar route - an over the door towel rack, and I converted one of the bottom decorative curls into a toilet paper holder. Our TT really didn't have room for a towel rack.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
04-22-2019, 02:29 PM
DaveAlb
All good fuel for thought...thanks!
04-22-2019, 05:14 PM
DaveAlb
Originally Posted by JS Stanley
How do you use the bungee cords?
04-22-2019, 05:41 PM
I plan on screwing a furring strip to the bathroom wall and then adding a towel bar to the strip. I hope to attach the strip to the FR "studs" that are behind the wall...most likely in the corners.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
04-22-2019, 06:10 PM
DaveAlb
Any special technique to locate the studs?
04-22-2019, 06:23 PM
Canadian Member
We have also used an over-the-door 3-hook towel rack. Just curious if anyone has ever used one of these Command Strip towel racks:
https://www.amazon.com/dp/B01C60C7FW...v_ov_lig_dp_it
04-22-2019, 09:05 PM
I just attach the cord to anything that it can grab. Pouches hanging in the shower, the curtain hooks, and outside of the shower is some netting for above storage.
04-22-2019, 10:03 PM
Actually did install the towel rack that came with the trailer. Unfortunately I went to use my level not thinking the trailer was off. Now it is a little unlevel [emoji21]🤣
04-23-2019, 09:00 AM
DaveAlb
I bet the towels will still dry just fine though.
04-23-2019, 09:14 AM
It's an interior "wall" that's mostly sounds hollow with my finger taps. But the corners of the wall is solid..that is where the screws for the furring strip will go.
04-23-2019, 10:52 AM
DaveAlb
Thanks!
04-25-2019, 03:45 AM
Regular Stud finder works too.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
04-25-2019, 08:29 AM
DaveAlb
I’ll try it...thanks.
04-25-2019, 09:31 AM
That's exactly what I did. The "studs" weren't exactly where I would have predicted (imagine that!) but I located them with my regular stud finder.
... and, yes, I finished those screw holes.
I made it level by measuring up from the floor instead of basing the position off the rounded ceiling or using a level in a not-quite-level trailer.
04-25-2019, 09:58 AM
We went to Lowes and bought a Moen Towel bar and Toilet Paper holder...Had no problems mounting them in my trailer on the hollow wall with no studs they have been on for a few years now with no issues
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
04-25-2019, 10:06 AM
I posted this a couple years ago on a thread about wall anchors (I've used them and they do hold):
A well nut may also work. It's a rubber piece, with a lip, that has an enclosed nut within the rubber. You insert the well nut into a small, drilled opening in the wall. As you tighten a machine screw in the threads, the rubber on the well nut, on the inside of the wall, will compress and expand against the wall and the larger lip of the nut, on the outside of the wall, holds it in place. They can be removed anytime by simply loosening the machine bolt.
They can be found on eBay and Lowes sells them...here's a link:
https://www.lowes.com/search?searchTerm=well+nuts
