Old 02-08-2016, 03:20 PM   #11
bareftn's Avatar
well I must be the only one . I would go with the full over ride spring or go to a spring shop and add a leaf or two if needed I did not buy my first f 250 4wd for a soft ride I wanted a truck that when ever I put any kind of load in it I could load and go and not mess with putting air in the system but that's just me if I wanted a soft ride I would buy me a girly truck
bareftn is offline   Reply With Quote
Old 02-08-2016, 03:53 PM   #12
Originally Posted by tom_sanfelippo View Post
I have a 2014 Dodge Ram 3500 Turbo Diesel Dually with a full length bed. It seems to haul our 43' 2015 Forest River Sandpiper fine. Though, it does squat down when we connect it. Is it advantageous and worth the cost to invest in Air Bag Suspension? I'm happy with the ride but would do it if it saves problems with my truck. Please advise. Thank you!!
One of those can't hurt for the most part kind of items. I do not think it will "save" your truck from anything. I have a 2014 dually 3500 and the payload on it is 5975pds. Yours depending on the options will be close to that! This post mostly have 250/2500 trucks carrying campers like yours where they have used up 3/4 of their payload just dropping the dry trailer on it. Your max hitch of 2500pds is not even taking up half your payload.
2015 Sandpiper 30IOK
2014 Ram 6.7 CC DRW
2006 Charger RT
X96mnn is offline   Reply With Quote
Old 02-08-2016, 05:01 PM   #13
Todouble's Avatar
Takes a touch of a button and about 5 seconds to pump airbags up. Not hard at all. All done from the cab on my truck. Plus you can adjust the ride to match the load.
Todouble is offline   Reply With Quote
Old 02-11-2016, 12:32 AM   #14
Like air bags and have had them now on 4 different tow vehicles. Probably never have another truck without them. Some kits have two separate hookup to manually put air in bags. Friends of mine years ago had one bag go down due to a rock puncture and it nearly threw him off the road. Ended up in a ditch with the truck seriously up on one side and dragging low on the other.
I now put in one tap to put air in both bags. If one bag goes flat, both go at pretty close to the same time. Rather have no bags or both bags with air than one bag filled and one empty.
I put the air tap inside the fuel filler door, keeps it clean of dirt, etc. Sometimes have to use a very short extension on the filler valve to be able to get the air hose on. Unless, of course, you use an onboard compressor. I had it once and it was both expensive and troublesome. Now I use about the cheapest 12 volt compressor I can buy that plugs into the cigarette lighter. Current one cost less than $10.00 and while a bit slow, it works fine. If it breaks, I can replace it for less than $20.00. Lot cheaper than an onboard set up, less wiring and fewer complications.
MacII is offline   Reply With Quote
Old 02-11-2016, 01:44 AM   #15
bareftn's Avatar
that's anther reason I have always added a spring or a full overload spring
Old 02-11-2016, 09:44 AM   #16
Take a look at the SumoSpring. They are a progressive spring which will not rupture. Looks like a great option for both front and rear.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
