Old 03-28-2014, 11:38 AM   #11
fonzie's Avatar
I think this type would suit you....might be noisy but will do the type of use you describe.
Amazon.com: Pro-Force VPF1080318 3-Gallon Oil Free Air Compressor with Kit: Power & Hand Tools
Fonzie
Old 03-28-2014, 12:09 PM   #12
Triguy's Avatar
The PORTER-CABLE C2002-WK Oil-Free UMC Pancake Compressor is what I use when at home, but would work on the road if you have a bigger basement and a generator or shore power.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-28-2014, 04:32 PM   #13
Post
I carry a small pancake compressor from Harbor Freight with me. It has done everything I needed it to do so far. Think I paid $35-$45 for it.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 03-28-2014, 08:08 PM   #14
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Bob
I was thinking about getting that one myself for emergency use when traveling. I have a coupon for 39.95 and realize that it will be noisy and probably take some time to inflate tires to 65 or 85 psi. Would not think it would work in case of a flat but would work to top off tires a few pounds. It only weighs 21 pounds so that's a good thing too. When I winterize I blow out the lines and add antifreeze too, so even if the 1 CFM at 40 psi is a bit on the light side, I have the antifreeze there too. Here's a link to it at Harbor Freight.
Pancake Air Compressor - 3 Gallon, 100 PSI
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 03-28-2014, 08:49 PM   #15
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
my brother-in-law bought one like fonzie posted from Sears. Works ok but takes a few minutes to fill tires, tank runs out fast. So many opinions and their all good, only needs to please you.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 03-28-2014, 09:08 PM   #16
ironj's Avatar
I keep a 3gal cake in the storage bay...good for tires, n airbags......I will say that to take my 20" tires from low at 50psi to 65-70 takes a while....like 8-10 min of running....mind you it would inflate any tire in a pinch.....but it may take a while.....and forget blowing lines out with it....you CAN but its agonizingly painfully slow...I use the craftsman 30 gal for that...and keep a 60 gal in the shop for constant duty like painting, grinding, or using the da to polish
sent from fat fingers via a space dish thing with no regard to grammer.
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 03-28-2014, 09:20 PM   #17
Ford Idaho's Avatar
I have a Sears evolv, it has done all I need of it including airing up the 17" tires on my PU.
I paid 59.99( I think) on sale.
Sears.com
Old 03-28-2014, 09:36 PM   #18
ironj's Avatar
I had one of those. ..its the same as a harbor freight...100psi 1scfm at 40 psi.... (obviously better quality) but it would still be a lil scant to blow out lines
Old 03-28-2014, 09:37 PM   #19
ironj's Avatar
Mine got stolen out of my truck... :-(
Old 03-29-2014, 04:58 AM   #20
Ford Idaho's Avatar
Have not tried it, my trailer is factory set up for pulling the pink right out of the jug so I do it the easy way.
Two gallons in and I am done took about 1/2 hour if I remember right.
Well that blows!!!
