Old 08-18-2019, 05:04 PM   #1
Align tt axles?
So im wondering can someone re align the axles on the a tt.. i have a twin axle thats a torsion style and i noticed the right front tire as some abnormal wear on the inside of the tire. Can they be realigned?
Bbouch84 is offline   Reply With Quote
Old 08-18-2019, 08:10 PM   #2
david_reaves's Avatar
I had the same issue. After some potholes, it got worse... I was told that the torsion axles don't have any way to re-align. I ended up replacing the axle. There are some Dexter torsion axles that have replaceable spindles. You could check yours to see if that is possible.
david_reaves is offline   Reply With Quote
Old 08-18-2019, 08:32 PM   #3
Not sure how much wear you are having on the inside but my old travel trailer had one tire that was wearing on the inside. I jacked up that wheel up and noticed the bearings were loose on that hub. Allowed the wheel to sit out of line. Only affected the inside most part of the tire. I would investigate that before I went much further.
bigmurph is offline   Reply With Quote
axle
