Old 07-09-2012, 10:21 PM   #21
Dave_Monica's Avatar
It's alway a good idea to check your camper to truck clearance in a parking lot. Try turning full lock going forward and see how much clearance you have. Hopefully you still have some.
Backing up you can potentially get even closer to the cab, but at least your looking in that direction and see when you get too close.
Dave
Old 07-10-2012, 04:05 PM   #22
Md Jeff's Avatar
Originally Posted by Beausdog View Post
Its all good, what kind of trailer were you towing? what year? did it have the "new" rounded aerodynamic fronts that were designed for shortbeds? I thought I was close a few times to rubbing the cab but when I looked I was still 3 inches off. I know I cant go 90 degrees but I have made some pretty tight corners and backing into campground spots with no issues. Not saying ever wont or anyone else will or wont, just my .02
I was towing a Copper Canyon 29BH??, had towed it numerous times previously with no issues, just tried to cut it too hard forcing it in a site that was really tight, should have pulled up and cut one more time but didn't and it bit me, more pissed at myself for doing it that the fact it happened.... happy camping!
Md Jeff is offline   Reply With Quote
Old 07-10-2012, 04:07 PM   #23
Md Jeff's Avatar
Originally Posted by dunnnc View Post
Mine came with the Sidewinder. It was sitting on the lot. I think they all come with the Sidewinders now.
Guess I should have did some more checking before buying a slider
Old 08-29-2012, 11:43 AM   #24
Should not be a problem because you can always use a silder. Your problem is the 1/2 ton pick! A 30 foot 5er will be to much for the truck.
whj77372 is offline   Reply With Quote
Old 08-29-2012, 11:50 AM   #25
As someone else posted, rather that get into a lengthy discussion I will just say "I disagree"
Old 08-29-2012, 12:21 PM   #26
Rugged Brown's Avatar
And I have to agree with you. I'm pulling my flagstaff with a 1/2 ton Ram. I'm happy. I got the itch now to look at motorhomes though.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-29-2012, 01:15 PM   #27
DAISY BOYKIN's Avatar
The Ultra lightweight---------
The Rockwood / Flagstaff Ultra lightweight come with the Reese slider for short bed. I was just at the factory two weeks ago, the Rockwoods were being equipped with a slider that will work with just about any 5 th wheel
hitch. It is a brand new design by Reese, will work as a slider or stationary
hitch with a 5"6" short bed. There is a short video about the hitch from Reese on Utube.
http://www.youtube.com/watch?feature...Xer_5x9NY&NR=1
I have a F-150 5'6" bed with a PulRite auto slider hitch. Sure wish the Reese was out January 2011 when I bought the PulRite!!!!!!
I have no problem turning 90°, pulling or backing with the hitch I have with the Rockwood 8285 WS.
Good luck
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 08-29-2012, 02:49 PM   #28
Brigitte
boubou's Avatar
Ditto, pulling (jayco eagle HT 23.5) 5th wheel with 1500 Ram and no problem. Do I want a 3/4 ton? It would be nice. Do I Need it? Not unless I want a bigger 5th wheel
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 08-30-2012, 11:35 AM   #29
KyDan's Avatar
What size engine do you have?
What kind of MPG (honest- no guessing) do you get when towing?
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-30-2012, 11:44 AM   #30
hitch with a 5"6" short bed. There is a short video about the hitch from Reese on Utube...
I think the terminology might be in error, I think they are called the Reese Revolution Sidewinder and they DO NOT SLIDE, they can be made to pivot at the hitch pin or by removing 2 bolts in the rear and installing the wedge behind the hitchpin, they will pivot back 22" from the hitchpin, but they won't slide.
5th wheel, bed
