Old 06-14-2015, 07:46 PM   #1
anyone pulling fifth wheel with ram 2500?
I was wondering if anyone is pulling 5th wheel with ram 2500 diesel. If so, what model?
In the spring we bought a travel trailer where the dealer swore we could pull with my old ram 1500..... he was wrong. Now after experiencing the great fun of camping, i am considering trading travel trailer for a 5th wheel but don't want to have to upgrade truck to 3500.
craignhouston is offline   Reply With Quote Reply
Old 06-14-2015, 07:50 PM   #2
Flagstaffer06's Avatar
You can find many fifth wheels that a 2500 diesel would tell very well. What year Ram do you have? Do you know the payload and towing capacity? That will help you determine some pin weight numbers and also your towing capacity. You'll hit the payload first.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote Reply
Old 06-14-2015, 07:55 PM   #3
Ford Idaho's Avatar
What are the odds that you will never buy a bigger trailer than the one you have now?
Are you sure?
Get the one ton they are not that much more than the 3/4.
Ford Idaho is offline   Reply With Quote Reply
Old 06-14-2015, 08:02 PM   #4
GmanHawaii's Avatar
I tow with 2500. only difference between a 3/4 and 1 ton are the overload springs. You can buy a set of airbags online for 354.00 that will do the same thing as overload springs, difference is when you do not have a load or pulling a trailer you can let some air out of the bags for better ride, overload springs will still ride like S when empty.
You can also install a Smarty or Edge tuner that will give you all the power you could possibly want.
GmanHawaii is offline   Reply With Quote Reply
Old 06-14-2015, 08:24 PM   #5
jtstromsburg's Avatar
Appears you have the ram 2500 already. I pulled a 40' 13K lb + fiver for two years with a gas burner f250 and the only problem was due to ice. I now pull the same model camper with a 1T drw and can really tell a difference, but the 3/4t was fine.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote Reply
Old 06-14-2015, 08:46 PM   #6
Originally Posted by craignhouston View Post
...but don't want to have to upgrade truck to 3500.
Originally Posted by Ford Idaho View Post
... Get the one ton they are not that much more than the 3/4.
I think OP explained that in his post.
OldCoot is offline   Reply With Quote Reply
Old 06-14-2015, 08:54 PM   #7
davel1971's Avatar
very, very wrong. The springs with a 1 ton add MUCH more payload. Air bags DO NOT add payload. My 1 ton rides better than my 3/4 ton I had. The overload springs do not effect the empty ride what so ever because they aren't touching anything.
David & Lynn
davel1971 is offline   Reply With Quote Reply
Old 06-14-2015, 09:17 PM   #8
mud yapster's Avatar
My new Ram 3500 dually Crew Cab Long Bed 4x4 with 6.7L rides smooth empty or loaded and pulls my 18k 5er and get 11.5 mpg on rolling hills. Aisin tranny and 3.73 axle gives it 33,200 GVWR and if you get that set up with a 4.10 axle it's rated at 37,800 GVWR. But to get those ratings you need the Aisin tranny. Can't go wrong with Ram or Ford diesels. I almost can't tell my 18k 5th wheel is back there and the engine brake is excellent.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote Reply
Old 06-14-2015, 09:40 PM   #9
asquared's Avatar
Do you have a ram 2500 now? If so, provide more info on it do we can help you (year, payload, GVWR, GCWR, RGAWR, etc). If you don't have the 2500 yet, I also suggest just getting the 3500. My 3500 rides just as good as my old f250, maybe even smoother and has more than double the payload capacity as well as better fuel mileage. Towing down up and down a 4.5 mile 8% grade this weekend with a 12000 lb fiver, I was quite happy with my truck choice.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote Reply
Old 06-14-2015, 10:34 PM   #10
GmanHawaii's Avatar
B.S. the trucks are Identical, same engine, same trans, same rear end same springs. Call dodge yourself, don't take my word for it, they'll tell you the same if you want to make your truck a one ton add the overload springs.
As far as airbags increasing payload your wrong. Research it for yourself.
Old 06-14-2015, 11:04 PM   #11
GmanHawaii's Avatar
And the over load springs do effect the ride because though the truck is not loaded to the point that the ends touch, the middle is still part of the stack of springs.
Old 06-14-2015, 11:47 PM   #12
Taranwanderer's Avatar
I'm pulling my 5-er, around 12k, with no major issues (except that the stock clutch is going to have a short life and will need to be replaced with a South Bend soon.). I put the whole rig on the scale at my local stone quarry last month, nothing in the garage but with a full load of water: 19,400 pounds. The truck had its axles swapped to 4:10 ratio (that was never available from the factory with the manual transmission,) so my unloaded mileage isn't great, but it tows well. Good luck!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote Reply
Old 06-15-2015, 12:18 AM   #13
SKnight's Avatar
I am, and so far it's been no issue.
If you don't have a 3/4 ton already do shop for the 1 ton trucks also. There's no denying that there's a difference in stability, but if you already have a 3/4 ton then roll with it, just keep the weight ratings in mind.
SKnight is offline   Reply With Quote Reply
Old 06-15-2015, 05:21 AM   #14
davel1971's Avatar
I didn't say there were any other differences in the 2 trucks, we are talking about springs. Rear springs is the only difference in a 3/4 ton and single wheel 1 ton. We agree on that but yet you are trying to school me on trucks. I've been to the websites of air bag manufactures, and they say themselves that they are for stability and ride control only, and not to increase payload.
David & Lynn
Old 06-15-2015, 05:24 AM   #15
arpipeliner's Avatar
2008 Dodge Ram 2500 4X4. The motor is heavy. The first time you get the motor down hill and need to back up on something slippery you will be wanting the 4WD.
Pull 2010 silverback 29RE. Put air bags on truck as I have a 100 gallon drag up tank. 5ver is just under 35'.
arpipeliner is offline   Reply With Quote Reply
Old 06-15-2015, 05:33 AM   #16
davel1971's Avatar
from the Airlift website:
Q. Will adding air springs increase the Weight Rating of my vehicle?
A. No. Adding air springs will not change the Weight Rating (GVWR, GCWR, GAWR) of your vehicle. Our air springs simply increase your suspension’s ability to support heavy loads. We strongly recommend that you never exceed your vehicle’s Weight Ratings. Exceeding your vehicle’s rating is dangerous and will void your Air Lift warranty.
David & Lynn
Old 06-15-2015, 06:16 AM   #17
What Davel1971 said ^
Pipeman is offline   Reply With Quote Reply
Old 06-15-2015, 08:09 AM   #18
MtnGuy's Avatar
Wow on that statement. The 2500 Ram trucks I have been looking have those coily things over the rear axle, and the 3500s have those long flat thingys over the rear axle. That doesn't appear to be the same for this ol' boy.
MtnGuy is offline   Reply With Quote Reply
Old 06-15-2015, 08:23 AM   #19
So, by your own admission you bought too much trailer for your truck. Now you want to do the same thing again? I dont understand your logic of buying a bately adequate tool for the job at hand. 2500 series trucks can handle a fiver, as long as you keep it under about 10,000 GVWR. Meaning a fifth wheel in the range of 25 feet. Not knowing how big any future trailer purchases might be quit playing the buying game and get the right truck the first, second in your case place.
donniedu is offline   Reply With Quote Reply
Old 06-15-2015, 09:04 AM   #20
A 3/4 ton Ram had coil springs and a 1 Ton Ram has leaf springs. The 1 Ton still rides smooth unloaded.
500, fifth wheel, wheel
