Old 06-08-2012, 08:24 PM   #31
Rsgtivr6's Avatar
Originally Posted by Dave_Monica View Post
Towed the camper in our signature with a '05 Ram 5.7 QC SB RWD. Our pin weight then was 1240 lbs which put the truck over it's GVWR and just under it's RAWR. The camper you're looking at will have a pin weight more in the 1600 to 1700 lb range...well over the trucks RAWR for sure.
If you're determined to stick with a half ton, look at the new F150's with the max tow and payload options. It would handle that fiver you're looking at.
Dave
Or a Tradesman HD Reg Cab Ram (if you want to stay Chrysler) if you just want a TV and don't need more than 2 people.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-08-2012, 10:59 PM   #32
FreedomTracker's Avatar
Saw this on another thread today posted by MilCop4523. I'm sure there are FR parts in there somewhere.
Might work on an F-150 6.2L or EcoBoost....
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 06-08-2012, 11:48 PM   #33
Rsgtivr6's Avatar
The big flat wind slapper front on that would match the F-series well...
Ok blue oval fans, I am just playin. Nothin but <3
Old 06-21-2012, 07:25 PM   #34
VacaBill's Avatar
150 towing
If you are happy with your current trailer, I have two suggestions, first do you have light truck or passenger rated tires? LT tires have much stronger / stiffer side walls and help with sway and control. Second, I am pulling a Rockwood 2703SS and experience sway. I purchased a Hensley Hitch, absoloutly amazing!
VacaBill is offline   Reply With Quote
Old 06-21-2012, 07:47 PM   #35
dretired's Avatar
i thought this thread is about towing a 5th wheel with a F150.. or is that Hensley a 5th wheel hitch ??
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 06-21-2012, 07:52 PM   #36
Maybe Hensley is making a 5th wheel hitch now.
Old 06-22-2012, 09:22 AM   #37
BigTJohn's Avatar
I currently tow a GREY WOLF 26RL w/RAM 1500. Max, as stated for my truck is 7400 as equipped. I have weighed my trailer and I am quite a bit under weight BUT, I borrowed a friends 2500 RAM one day and it is WAY BETTER at handling the weight. Easier and better handling, truck sits better and more level w/same WDH at same truck hitch height. Mine is OK but I will be looking to upgrade 250/2500 series truck in the future. Just safer to have something which is not near or at max limit. Also easier on the vehicle.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 06-22-2012, 09:50 AM   #38
Originally Posted by TRAVLINOHIO View Post
Looking at a keystone cougar x-lite 28 sgs. Anyone have a similar set up?
Do your homework and run the numbers yourself.
RV and Tow Vehicle Weights
Hope this helps.
grayfox is offline   Reply With Quote
Old 06-22-2012, 06:51 PM   #39
MIKE44460's Avatar
No, I have the 4.6 3v 3.73 gear Sticker says gvwr is #7000, Trailer rating is #9400, gcwr is #15,100. I am towing a 30kqbss now, and it weighs more than the fifth wheel, am I over loaded now? The only issue I have now is it is swaying of the trailer even with the equilizer WDH.
Hensley Arrow. If you want to see mine, I live near Alliance, be happy to tell and show you all about it. PM if interested.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 06-27-2012, 10:13 AM   #40
Well, I towed the Salem hemishpere fifth Wheel once with the F-150, and found a deal on a Ram 2500 with the 5.7 HEMI, so I upgraded. It wasnt that the F-150 did a poor job, but I didnt feel safe doing it after all of the feedback I recieved!
Steve
13 days reserved in 2012 so far!!
TRAVLINOHIO is offline   Reply With Quote
led pad
