Old 05-30-2012, 08:21 PM   #1
Anyone tow a fifth wheel with a f-150??
Looking at a keystone cougar x-lite 28 sgs. Anyone have a similar set up?
Steve
13 days reserved in 2012 so far!!
TRAVLINOHIO is offline   Reply With Quote
Old 05-30-2012, 08:53 PM   #2
TURBS's Avatar
10,000 gvw hmmmm
7574 dry
2426 ccc
specs on truck ?
Old 05-30-2012, 09:02 PM   #3
2010 f-150. 4x4, hd tow package, extended cab. 9700 towing capacity
Steve
Old 05-30-2012, 09:05 PM   #4
TURBS's Avatar
someone will be around to run the numbers but just glancing it will be on the edge imo.
whats your trucks ccc ?
pin weight on this unit is 1410
Old 05-30-2012, 10:24 PM   #5
Ecoboost yes, otherwise you are on the edge.
For short distances, you would probably be ok.
But definitely not a preferred setup.
DonG is offline   Reply With Quote
Old 05-31-2012, 06:44 AM   #6
gcwr #15100, max trailer weight is #9400
Steve
Old 05-31-2012, 07:19 AM   #7
Rsgtivr6's Avatar
So roughly 5400 curb on truck (not too off the wall guess but we don't have much to go by and 15100 GCVW minus 9700 max tow = 5400 left for truck @ curb minimum) and 8300 in the 5er with avg loading puts you at 13700. Fully loaded 5er with *empty* truck (just you and gas) at 14800. that doesn't include accessories, hitch, more people, etc
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 05-31-2012, 07:38 AM   #8
TRAVELINOHIO, you do have the 5.4 we are assuming?
Old 05-31-2012, 07:55 AM   #9
No, I have the 4.6 3v 3.73 gear Sticker says gvwr is #7000, Trailer rating is #9400, gcwr is #15,100. I am towing a 30kqbss now, and it weighs more than the fifth wheel, am I over loaded now? The only issue I have now is it is swaying of the trailer even with the equilizer WDH.
Steve
Old 05-31-2012, 08:05 AM   #10
dretired's Avatar
here is mine..Click image for larger version
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
led pad
