Old 10-17-2015, 07:48 AM   #1
Are we being too fussy
Good Day All,
We have had our first brand new TT, a Vibe 268, for a couple of months now. After a couple of weeks of buyer's remorse, I can say we love it. Just had the best Thanksgiving weekend ever in it. (Yep, we are Canadian)
Why buyer's remorse - the build quality is shocking (and it is a bit longer than we realized, but that is totally on us). I have rehung the bathroom door so it stays shut, resealed the top of the shower, remounted the shower head support, and accepted that Forest River use their accountants to do the welding (no welder would accept the quality of our welds, but the accountants would accept the cost savings ) I put the general quality down to weight saving - which I can accept.
As we get ready to winterize the TT I wonder what everyone's opinion is on the remaining issues.
1 - the awning has a very small hole in it. It looks like it will spread. Our dealer have suggested they will patch it. I don't want a brand new TT with a patched awning. Am I being unreasonable.
2 - the myRV linc blows its 30A fuse everytime we use it to bring the slide out in. The dealers fix is to replace the fuse. Any thoughts what this could be so I can suggest a better fix. I am sure we are not being fussy here! FWIW - when we went out last weekend the battery was also completely flat. Not sure if this is connected
3 - the shade behind the lazy boys will not stay up. Are these adjustable or do we need to request this gets replaced.
4 - and finally, the fridge in the outside kitchen sits so low the door will not open. Does anyone have a tidy fix for this? I have it resting on a couple of 1 x 3s
Wow - that turned into a long post. We love our trailer, very sad to put it to bed for the winter, but would like some guidance on our remaining issues.
Thanks all.
Bored Engineer is offline   Reply With Quote
Old 10-17-2015, 07:57 AM   #2
Alleged curmudgeon
Vern's Avatar
With respect to #3, if those are day/night type shades you are talking about, you may be able to adjust (re-tension) the cords to make them a little tighter. Often a small adjustment is all that is required.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 10-17-2015, 08:00 AM   #3
Alleged curmudgeon
Vern's Avatar
With respect to #1, hard to say without more info. You'll find plenty of folks on here who will want to hijack your thread with rants about poor quality, the fact (who would disagree) that this is "not acceptable on a new TT", and "lawyering up". My TT is 3 years old and I found a pinhole in the awning this spring, which a piece of clear awning repair tape seems to have fixed to my satisfaction. However, I was beyond warranty and had no sense this will spread (post-repair).
Lee
Old 10-17-2015, 08:03 AM   #4
Alleged curmudgeon
Vern's Avatar
With regard to blowing the fuse when extending your slideout (your issue #2), I would not find that acceptable. A fix is needed. I'd press the dealer and, if not capable, Forest River, to make that right.
Lee
Old 10-17-2015, 08:04 AM   #5
clr
Regarding number 2 in your post. It is not normal to blow the fuse each time that you run your slide in or out and just replacing the fuse is not fixing the root cause of the problem. There is something wrong here that is causing the slide motor to draw to much current therefore blowing the fuse. This may be related to your battery have them check out the battery as well as the converter.
clr is offline   Reply With Quote
Old 10-17-2015, 08:04 AM   #6
Alleged curmudgeon
Vern's Avatar
#4 calls out for a little owner ingenuity...but I'd inquire why this design is like this and whether there is a recommended fix (dealer and FR should be able to explain how it is intended to be used as built) before resting comfortably that I was happy with whatever fix you (or they) employ.
Lee
Old 10-17-2015, 08:05 AM   #7
Alleged curmudgeon
Vern's Avatar
Agreed...
x2
Lee
Old 10-17-2015, 08:07 AM   #8
Georgia Frog Rally 2018
aceinspp's Avatar
[QUOTE=Vern;1011931]With respect to #1, hard to say without more info. You'll find plenty of folks on here who will want to hijack your thread with rants about poor quality, the fact (who would disagree) that this is "not acceptable on a new TT", and "lawyering up".
X 2 regarding Item 2 and 4 I would take them back for warranty work. Just replacing fuse all the time is not normal and a frid that is sitting to low show be there responsibility. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 10-17-2015, 08:14 AM   #9
trbomax's Avatar
You only have 4 items and you think you may be too picky???? We have 3 pages with 18 items (make that 17,Ifixed one myself yesterday while winterizeing).
trbomax is offline   Reply With Quote
Old 10-17-2015, 08:15 AM   #10
B and B's Avatar
Sounds like there is some type of feedback loop (hall sensor or proximately sensor) on the slide that is not working correctly. With manual switches the person see the slide at the end or hears the motor labouring/ grinding and lets go of the switch. Withe tablet i almost would think some delay exists and therefore there should be some feedback loop to tell it to stop. I say there is a design problem with the Linc system or faulty equipment.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
