Old 06-13-2018, 11:22 AM   #1
Awning Door Roller
Our entry door rubs the awning. Door is curved corner, not sharp 90 degree. Wondering how many of you with same issue have installed the roller on the door? If so, why? It doesn't rub hard so I don't think it would be an issue, but want your opinions. Thank you.
ard58 is offline   Reply With Quote
Old 06-13-2018, 11:28 AM   #2
jeff64's Avatar
If this is an electric awning and the awning is fully open, this happens. If you close/retract the awning just enough so the flap hangs straight down, 1. The awning will be just high enough so you don't need the roller and 2. there will be just enough wrap on the fabric to reduce the stress on the attaching seam at the roller
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 06-13-2018, 12:35 PM   #3
Haven't really had a problem with mine yet, as long as I have the awning set to be straight out.
I added the new Camco Roller ball just in case. $6 or 7 via eBay.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
awning, door
