Old 06-30-2015, 02:18 PM   #1
Awning Malfunction
As we were heading north toward some great camping in Spooner, Wisconsin over the weekend we came upon a TT in front of us. Just as we caught up, the awning on the TT extended (at 60 mph) shredding the awning and mangling both support arms. How does that happen and is there something that should be done to guard against it?
Live your life as if you just sold your parrot to the town gossip...............
dratcliff is offline   Reply With Quote
Old 06-30-2015, 02:30 PM   #2
that's a good question, hope someone has a reply to this.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-30-2015, 02:32 PM   #3
TURBS's Avatar
I believe oc made an awning lock, other then that? I think it'll just happen.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-30-2015, 02:34 PM   #4
fonzie's Avatar
There are a few threads on awning locks.....you can do a search above....
Awning Lock
http://awninglock.com/index.shtml
Fonzie
Old 06-30-2015, 08:03 PM   #5
wbdavey's Avatar
My solution follows the KISS principle. I wrap a velcro strap (about 10"long made by Camco) around each awning arm. They're thin enough to slide behind the part that bolts to the trailer.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 06-30-2015, 08:06 PM   #6
Sorry to tell you, but locking the arms will not keep the awing from unrolling on the tube if the motor goes south. Once the motor turns loose, the torsion spring will automatically unroll the material.
Old 06-30-2015, 08:32 PM   #7
GLCM Warrior
Lefty59's Avatar
Save Your RV Awning with an RV Awning Travel Lock!
I installed the awning lock (in the link above) on our Wildcat this past weekend. Install was simple & easy.
Now, I just need to label the switch to remind the awning operator (namely me) to release the lock before attempting to deploy the awning.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 06-30-2015, 09:20 PM   #8
arpipeliner's Avatar
If manual awning I put a u bolt style around the arms cause I didn't understand the locks completely. My father drives a truck for a living. He said blow outs and awnings is he what he had noticed.
Haven't worried about the electric awning. Again I don't know everything about them. The only sure thing I could see be a racket strap placed between the camper and awning. I don't want to have to deal with the chaping of the strap on the camper.
Seen OC has made a locking device but I haven't had a scare or the home base to build anything like that.
arpipeliner is offline   Reply With Quote
Old 06-30-2015, 09:34 PM   #9
Flybob's Avatar
Might try something like this ( see below) . I use these on the knobs that lock down the dump function on the awning . I never forget to loosen knobs before closing awning. Also have one on power connector to remind me to check WH switch.
Robot Check
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-30-2015, 09:43 PM   #10
Boss Hoss's Avatar
Hope you don't have a Dometic awning with a bad motor..like mine!!
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
awning
