Old 02-24-2013, 05:33 PM   #1
5verdriver's Avatar
Axle ratings
After doing countless hours of research and traveling to shows to look at new fifth wheels, lately something crossed my mind and that is, the coach we bought ( 2012 Palomino Sabre 36 QBOK ) has a gross of #15825. We bought the coach from dealer stock and happened to have the 'optional upgraded' #7000 axles, normally comes with #6000 axles. If you do the math, there is #1825 that's not accounted for. I am assuming that difference would be the pin weight. Can anyone confirm that? Makes sense to me. Thanks.
2013 Palomino Sabre 36 QBOK-7
2012 Ford F-350 SRW 6.7 CrewCab ShortBed
PullRite SuperSlide 18k IS Rails
2006 HarleyDavidson RoadKing Classic
5verdriver is offline   Reply With Quote
Old 02-24-2013, 05:41 PM   #2
AquaMan's Avatar
You are correct.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-24-2013, 06:27 PM   #3
Dave_Monica's Avatar
Pin weight isn't on the axles. The manufacturers determine the camper's GVWR by adding the axle ratings to the dry pin weight.
Dave
Old 02-25-2013, 07:17 PM   #4
5verdriver's Avatar
Dave, I realize the pin weight isn't on the axles, however, it's obvious even while parked (unhooked), the axles and the landing gear are supporting the weight of the unit. All I was trying to surmise was, while hooked to truck, that 'difference' (#1825) was transferred to the pin. The thing that doesn't make sense to me is, for the person who buys the same trailer with the #6000 axles, that would mean THEIR pin weight would be #3825----I don't think that's right.
Old 02-25-2013, 07:26 PM   #5
Campingnut's Avatar
No there gross trailer weight would probably be 13825, 12000lbs for the 2 axles plus the pin weight.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 02-25-2013, 07:43 PM   #6
QCCowboy's Avatar
Not sure if this helps or not but the build sheet for the 2013 QBOK indicates that the 7k axles are not optional but mandatory (a mandatory option). This may have been the same on the 2012.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 02-26-2013, 08:38 AM   #7
Fulltime family RVer
It was the same back then- from talking to the factory rep at the time, we literally were stalking the 36QBOK from the time it was in the final stages of pre-production through orders from dealers. Their pre-production unit made the decision to only put 7k axles under them.
ependydad is online now   Reply With Quote
