Old 08-30-2015, 01:25 PM   #1
Axle Weights
New to fifth wheels and I would like to balance my axle weights a little better. The fiver is slightly nose high. Will raising the trailer 2 5/8 to 3 inches (kits from Dexter for Torflex axle) make much of a difference? Has anyone raised the trailer to equalize axle weights?
Torflex 4000lb wt axles
Weight - front 3380 rear 3920- unit weight close to what we travel with
2014 Ram 2500 Bighorn CC SB CTD 4X4
2016 Flagstaff 8528IKWS Platinum
2013 Keystone Hideout 23RBWE -Sold
randygk is offline   Reply With Quote
Old 08-30-2015, 03:26 PM   #2
WolfWhistle's Avatar
The weights you posted, are those front and rear axles weights? I would guess it is, since torflex axles don't equalize like traditional leaf spring setup. I would think that lifting it would move some weight from rear to front axle, yes. I think I would do it, since nose down should tow better, but what the heck do I know.
Is 4000# torflex for each wheel... or the pair? My little TH has 5200# axles (leaf springs).
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 08-30-2015, 03:32 PM   #3
4000 lb per axle
Old 08-30-2015, 05:45 PM   #4
I was thinking the "axle" doesn't run side to side... independent as it were??
Old 09-04-2015, 11:13 AM   #5
arpipeliner's Avatar
If your bed rail to fifth wheel clearance is over 6" to 7". You could raise the hitch or lower the fifth wheel while maintaining proper clearance to get a level riding camper. Just a thought.
arpipeliner is offline   Reply With Quote
Old 09-04-2015, 11:49 AM   #6
About 5" now, not sure I want to lose any clearance as I'm on uneven property. I've requested a quote for new axles so will see if that will work. We knew this may be an issue when buying the trailer.
Old 09-04-2015, 12:00 PM   #7
Old Enough to Know Better
gasman6674's Avatar
I'm assuming you cant shift any "stuff" forward?
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 09-04-2015, 12:03 PM   #8
Commercial Member
I suggest you look at THIS site for 5th wheel weights.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 09-04-2015, 12:29 PM   #9
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I just looked up the specs. of your 5er, I like it
Flagstaff Classic Super Lite Fifth Wheels / Travel Trailers by Forest River RV
I'm a little surprised they get away with 4,000 # axles, you're already at over 90%, better to keep a close eye on axles, bearings and especially the tires.
Leveling the load (trailer) would definitely help with distributing the weight better between both axles. Looking at your pic., I don't see how you could lower the front end without risking some nasty mishap sometime down the road. If I had to do it, I would get the lift kit and plan for an axle upgrade down the road. I know it's expensive, but you'll be a lot happier in the long run.
Edit: Kudos for paying attention, some folks just hook up and go and then complain when something goes wrong.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-04-2015, 01:23 PM   #10
May just bypass the lift kit (which Dexter recommend against using) and upgrade the axles to start with. The upgrade being the same load rating, but starting angle of 45 degrees to lift the trailer about 2 1/2 inches. Heavier axles start a whole new chain of events. I guess it depends on the price of the axles. We don't load heavy or do long trips and the trailer fits our needs.
Mostly Rv parks and will try to move some of the stuff forward.
I'm curious about lowering the front axle a bit to take more of the load with the trailer sitting as is.
axle, weight
