Old 10-19-2015, 11:26 AM   #1
BAL spare tire carrier for Silverback 29re
Has anyone installed this under frame spare tire carrier on a 2015 29re?
Not much room underneath the front but it may be possible to install behind the rear level up jacks.
WyomingJack is offline   Reply With Quote
Old 10-27-2015, 02:53 PM   #2
No responses yet ?! I did consider it but the negatives out weighed the positives ( for me ). If you do decide, make sure you can access it to inspect it easily and adjust air pressure. A flat or under inflated spare will do you little good in an emergency situation on a lonely road!! Find a spot in the rear of your truck and keep on keep'n on !!
SilverbackMel is offline   Reply With Quote
Old 10-28-2015, 08:49 AM   #3
No, your response was the first. Thank for the reply. My main concern was the distance from a mount behind the rear jacks on the level up system, ( just behind the axles ) on certain uneven roads such as steep RR tracks.
WyomingJack
2015 CC Silverback 29 RE
2014 GMC 2500 HD
tire
