Old 11-29-2015, 12:06 PM   #1
Battery Disconnect Cable
I am going to install a battery disconnect on my TT. Do I need to get a 2 gauge or a 4 gauge cable. Running 30amps.
southpaw821 is offline   Reply With Quote
Old 11-29-2015, 12:26 PM   #2
Ford Idaho's Avatar
I would think 6 AWG rated at 55A would be more than enough.
Old 11-29-2015, 03:55 PM   #3
I would just match cable size to what is already on the battery.
Papa GLS is offline   Reply With Quote
Old 11-29-2015, 09:56 PM   #4
They all "look" the same size.
Old 11-29-2015, 10:05 PM   #5
Who Dares, Wins
doc73's Avatar
If you look close the cable should say the size ex 6awg... It is usually not easy to see and might blend in but it repeats every few feet.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 11-30-2015, 07:23 AM   #6
They are & you do not want to go smaller or larger; keep it all the same size.
Old 12-01-2015, 01:00 PM   #7
kwoodrg's Avatar
whatever your existing cabling is--your added cabling should be no smaller or you will create a potential heating condition under load on that segment of cable.
2014 Dynamax Trilogy 37BH
2015 Ram 3500 DRW
2015 Ram 3500 DRW
kwoodrg is offline   Reply With Quote
Old 12-01-2015, 01:03 PM   #8
Flybob's Avatar
You don't say how far away from the battery you will be installing the disconnect.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-01-2015, 01:28 PM   #9
OntarioFireFighter's Avatar
You can go larger without an issue - but there's no advantage, either...
8 Ga would be fine for 30A, but I'd go with #6... 4 or 2 ga would be overkill but also wouldn't hurt anything but your wallet.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 12-04-2015, 05:52 PM   #10
New Member
RiverBird's Avatar
2x on 6. Larger won't hurt anything though
RiverBird is offline   Reply With Quote
battery, battery disconnect
