Old 07-05-2016, 09:20 AM   #1
howellma's Avatar
Battery power gone
So we are headed home from gulf shores, only a couple hours away, and I don't have any 12 volt power, battery is good and everything works when plugged in to shore power, no fuses blown, odd. 2012 solaire travel trailer, will have to do some checking when I get home
howellma is offline   Reply With Quote
Old 07-05-2016, 09:28 AM   #2
TURBS's Avatar
There should be a manual resetting circuit breaker near your battery, it may be under a red cover.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 07-05-2016, 09:41 AM   #3
howellma's Avatar
Ok, I checked , this is all I have before the wires dissappear under the belly, brakes seem to work and I have lights , should be good to get home
Old 07-05-2016, 09:46 AM   #4
wmtire's Avatar
Your resettable cb/fuse is to the left in your pic with the three wires (two are red) connected. There should be a little black button to push to reset, which appears to be on the right hand end of it.
2011 Flagstaff 831 RLBSS
Old 07-05-2016, 10:06 AM   #5
TURBS's Avatar
Battery power gone
What wmtire said.
Btw I think I can even see the reset button in the pic.
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-05-2016, 12:33 PM   #6
howellma's Avatar
10-4, we're home now, let me go check, thanks
Old 07-05-2016, 12:42 PM   #7
howellma's Avatar
Fixed! You know I work in the defense industry and we document everything so the sailor can fix anything on the deckplate, my manual leaves much to be desired. Two weeks and off to see the Blue Angels fly Pensacola!
Old 07-05-2016, 12:43 PM   #8
Mr. Dan's Avatar
Thanks for reporting your success.
battery, power
