01-09-2017, 11:38 AM
#21
The two trucks I've owned since I got my fifth wheel both came with the plug in the bed so I use those. In the past I've towed a lot of gooseneck horse trailers and used the bumper connection and never had a problem with it. If it isn't a big deal to add it I would go for it, otherwise you'll likely be fine without it. Just make sure the cord isn't going to hung up on anything and check the length when turning to make sure the length is sufficient.
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
01-09-2017, 01:22 PM
#22
Depends on the length of your cord. Too short and could pull out on a tight turn, too long and it Gould drag on the ground.
Joe & Joan
Fredericksburg, VA
F350 PSD DRW & Cardinal 3825FLR
01-09-2017, 01:32 PM
#23
I put 1 in my bed when I bought my dually because it makes it easy for me to use and I can't see a cord dangling and scratching my tailgate.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
01-09-2017, 02:17 PM
#24
My TV is a 2013 Super Duty with a 6.5 foot bed, my 5th wheel cord will easily reach the plug at the bumper with a lot of room to spare for tight turns etc. But saying this I opted to put a plug in the bed so I would not have to bend over all the time, tuff on the back ya know. Also Ford make it so easy to do this as well since you can buy a pre set up cord to run back to the wiring jack. Easy drill the hole, route the wire and plug it into the jack.
2015 Flagstaff 8528RKWS
2013 Ford F250 Super Duty
01-09-2017, 04:03 PM
#25
Could a fella measure the cord for proper turning length - remove his tailgate - plug in the cord - replace tailgate over the cord- maybe a pinching point, maybe not. May need to make a loop or loose knot with cord so the cord wont slide under the TG and onto the road....Just sayin....may need to experiment with it.
Bruce, Kansas
2016 Grey Wolf 26RR...100 nights camping since new
2006 Deluxe Harley Davidson
1993 Kawasaki KLR 650
1998 Polaris Sportsman 500 ATV
2004 f150 & 2008 f350 dually V-10
01-09-2017, 05:17 PM
#26
I live in Alberta,and I trailer into B.C.a lot. Have not yet heard nor had a complaint about bumper connections. My last three 5ers have all connected to the back bumper without damage to the cords or the tailgate.
01-09-2017, 05:20 PM
#27
For the past 6 years my 5ver(s) have been plugged into the rear bumper. that what my truck came with and none of the RV dealers have told me any different. Length of cord has not been a problem. On my last 5ver I used a bungee cord to keep it from rubbing the tail gate, but the new trailer has the cable coming out farther back and it easily clears the bumper. Then again, I only go out 6 to 8 times per year, so I am not a full timer
01-09-2017, 05:24 PM
#28
When towing with the 250 I just removed the tailgate, held the cord up with a couple of rubber bungee cords hooked in to a couple of holes (bed extender?).
Kept the cord off the floor of the bed and out of harms way.
01-09-2017, 05:43 PM
#29
I prefer the aesthetics and practicality of not having it drape over the tailgate. Fortunately it's as easy as ordering the right pigtail harness and flush mount connector from Mopar.
01-09-2017, 06:27 PM
#30
I think it is safer to have it inside the bed. No chance of running over something and knocking it loose or damaging it. In any truck I had that did not have a connector inside the bed, it was installed as part of the hitch installation without asking or discussing.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
01-09-2017, 06:40 PM
#31
three trucks and 2 5ers. Factory 5er cord and bumper receptacle. Never pulled loose, never rubbed truck or ground.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
01-09-2017, 06:54 PM
#32
I bought a rv plug assembly at my NAPA store it plugs into rear harness of pickup . No cut wires. Clean right and tight.About a hundred bucks,
01-09-2017, 07:25 PM
#33
I'm in both camps, My 03 Dodge Long Bed (8ft) I used just the bumper plug. It would pull the plug out if I took a sharp turn and had a ball hitch in the receiver. Some very minor tailgate rubbing as well.
The 2005 Dodge long bed I currently have has both in the bed and at the bumper. The original fifth wheel camper was pulled just a few times with this truck. Traded for the current bigger one and my car hauler is also a fifth wheel. Either plug location works fine with no issues. I have used both often.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-09-2017, 09:33 PM
#34
Hi,
I've used the plug on the rear bumper with every fiver and Chevy pickup I have ever owned. No problems with length of the power cord, or with it binding during turns.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
01-10-2017, 05:46 AM
#35
Originally Posted by MillerTime
I use the rear bumper plugs on all my trucks. I have plenty of cord on all my trailers and use bungees to keep the cord up and it will allow flex if needed for turns, but really have no movement of the cord since its attached at the back of the pin box.
If others like the plug in the bed and it works for them, thats great. I've just never had a need to run a 2nd plug.
X3
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
01-10-2017, 09:49 AM
#36
Blog: RVroadtripper.com
Dealer installed in bed when they installed the hitch. Seems very nice way to do it.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
01-10-2017, 09:28 PM
#37
Sounds like a pretty good split.
3 trucks and 2 5ers. 1st two trucks were on the bumper (no bed plug) and never an issue. My current truck, I use the plug in the bed.
I prefer it now. It is one of the last things I do when hitching up and I always take the opportunity to check the jaws on the hitch while plugging in.
j
2016 Coachmen Chaparral 390QSMB
2011 F350- CC, DRW, LB, PSD
2016 nights camped: 40
2017 nights camped: 16
2017 nights reserved: 30
01-11-2017, 01:09 PM
#38
It was one of the best suggestions that the mechanic at our dealer made. The only problem I have had is at the "Y" splice, because GM does not have a connector, you have to cut & splice the wiring. We have a 2500 Silverado & a Wildcat bought in 2010. PS: You should know that they are called Puss & Boots!!
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
01-17-2017, 10:57 PM
#39
Hey Wobbles, sounds like you got about half & half on the preference-meter with this question. I've towed 5ers lately with both plug-ins and the only downside I see is on the bumper plug with the new automatic tailgates on the Superduty trucks...gotta remember to hop out and un-plug before you touch the tailgate drop button. Tie a knot in the cable just as it tops the tailgate to prevent too much hang over and this prevents any rubbing on the painted surfaces.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
