10-18-2015, 02:23 PM
Best type RV for a Ford 150 SuperCrew Limited with 5 1/2 ft bed
With a Ford 150 SuperCrew Limited with 5 1/2 ft bed is a 5th wheel or travel trailer better ?
Cardinal 3450 RL
2000 Ford F-350 DRW
7.3 Powerstroke.
10-18-2015, 02:27 PM
look at payload for that truck. That's going to be the biggest factor. Bet it's pretty low
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
10-18-2015, 03:10 PM
Limited is similar trim to the King Ranch I owned. Payload likely 1600 to 1700 lbs.
B and B
10-18-2015, 03:25 PM
Yep, check the payload capacity amount and post it. It's on the driver door sticker.
You also need to post way more info on truck specs.
Year, engine, factory tow package or not, rear end ratio.
If it's Ecoboost, does it have Max Tow package or HD Payload package.
10-18-2015, 11:45 PM
Learning a lot as I go...
Sounds like he is not looking for absolute weight but tradeoffs between 5th wheel and bumper tow?
Has a short bed on it so he may have heard 5th wheel does not work?
10-19-2015, 01:13 AM
Interesting question posed by someone with cardinal and a dually In their signature. That said, more info is needed about both the capabilities of the truck and the weights of trailers being considered to give a fair answer.
2014 Sabre 34REQS-6
10-19-2015, 12:00 PM
Flagstaff & Rockwood 5rs have a factory installed Reese Revolution pinbox, for those type of trucks
10-19-2015, 12:17 PM
Following this discussion...
Was at an RV show this weekend, saw a couple of light-weight and ultra-light 5'ers that are well within my truck's capabilities; and have me re-thinking my "no 5th wheels on a half-ton" stance.
I'd be very interest in some real-world feedback...
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
10-19-2015, 12:26 PM
Realistically, if I put more than a 800lb. pin weight on my truck along with bikes, wife, and dog, then I am close to my GVWR, Not many 5th wheels out there with a 800 pin weight.
10-19-2015, 12:31 PM
Georgia Rally Coordinator
Guessing he may want to down size or checking for someone else. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-19-2015, 12:49 PM
Check your owners manual about if you can even pull a fifth wheel. It is not recommend to pull one on a 1/2 ton. I do believe the F150 is a 1/2 ton. How many people are you planning on sleeping in it?
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
10-19-2015, 01:29 PM
1+ Yrs of Trailering :0)
I am pulling a 2015 FR 2504S (about 5,000 lbs) with the same pickup (2014) that has a V6. It pulls fine on relatively flat land, but is a dog when going up hills. I am going to replace it with a V8, which should provide the power needed to comfortably pull the trailer and I'll likely get better gas mileage since it won't be as much a load on the engine and transmission.
2016 Ford F150 XLT Supercrew 3.5L EcoBoost (Twin Turbo V6 w/Max Tow)
2015 Rockwood 2504S MiniLite
10-19-2015, 05:59 PM
I pull a FR 8280 5er with a 1/2 ton Chevy. 1500 Silverdo with no problem .
2013 Silverado extended cab 4x4 1500 Series
10-19-2015, 06:11 PM
F 150
Seen a bunch in Myrtle Beach State park with Quebec on license plate.Thats a pretty good haul if you match the 5er with the 1/2 ton truck it will work yes short bed and all most were fords but a few Chevys
10-19-2015, 06:13 PM
looks like the OP is a "one and done" poster. We need lots more info before any accurate advice can be given
10-19-2015, 07:51 PM
Eh? Are you talking about the F-150? I pull a 7000 lb 2604WS up I-5 with a 2014 F-150 Ecoboost and I would not call it a dog at all. I have the power to pretty much go up anything at the speed limit. Only on the steepest/longest grades do I run into issues, and they are cooling issues not power issues.
BTW be careful with that "replace it with a V8" because it may not be better. I chose the Ecoboost specifically because it has more torque than the base V8. I love the sound of a V8 and have driven them for years. But this game is all about torque and the dual hairdryer V6 has it over the base V8s in the F-150s.
10-20-2015, 09:52 AM
towing with a SCrew
I have 2001 F150 supercrew and i tow a 2015 233s roo not having a problem till i hit really big hills then i dogs down a bit
Also you can look up your vehical specs here and it works for other trucks too
VIN Decoder - Ford F150 Forum - Community of Ford Truck Fans
2015 Rockwood Roo 233s
2012 Ram 1500 5.7 Hemi
10-20-2015, 10:24 AM
ARLO
We have a Flagstaff 829fkss TT with a dry wt of 6313#. I estimate that it is probably about 7100 or 7200 lb loaded and we tow it with a 2014 F150 EcoboostSuper Crew, Maxtow w/ E rated 10 ply tires on it. It pulls stronger than our 2005, 2008, or 2011 Super Crews similarly equipped but with v-8's (5.4l and 5.0l). Payload rating was 1900 lb with the standard tires. I? did put the heavier tires on it.
12-30-2015, 08:24 PM
Originally Posted by squbadoo100
That's a very good link. That said I have a '13 F150 ecoboost Supercrew 4X4 that pulls my Palomino easily.
2013 Ford F150 Ecoboost known as Lightning
Palomino Puma 31DBSS
12-30-2015, 09:14 PM
Ambassador
I am not a truck snob. I don't think you need a 20 cylinder, 6 axle 3 ton all wheel drive to pull a fiver. I do think with the right 1/2 ton it's totally possible. I think the weight distribution you need and the challenges posed by a short bed are daunting. You definitely need to find the right setup, and TT to pull it off.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
