Old 06-05-2015, 07:38 PM   #11
If you are pulling pin you are energizing the brakes if the battery is connected. If the breakaway switch is working. I have just purchased a brand new TT in Feb. I had to relocated the switch because weight distribution brackets. After reattaching switch I tested switch with volt meter 4 out 5 pulls of pin DID NOT work. replaced switch with a high quality switch.
uhduh camping is online now   Reply With Quote
Old 06-05-2015, 07:42 PM   #12
Ford Idaho's Avatar
In a breakaway event the trailers battery will activate the brakes.
Old 06-05-2015, 10:35 PM   #13
I use a threaded chain link coupler and hook it to the hitch itself, where the safety chains hook to.
2005 Flagstaff Shamrock 233
2008 Toyota Sequoia SR5 5.7l
Meadville, PA
Two adults, two kids, and on golden retriever!
2 Adults, 2 Children (7 & 5), and 1 3-legged Golden Retriever
Meadville, PA
Go Steelers!
brian19889 is offline   Reply With Quote
Old 06-05-2015, 10:50 PM   #14
Crockett's Avatar
Originally Posted by AVid View Post
When we had a TT, I removed a bolt from the license plate and replaced it with an eye bolt. Attached a snap clip to the cable. I reenforced the eye bolt on the back side with a washer and nut. All hardware was stainless steel.
John
x2
the breakaway only engages when the pins pulled...brief periods to connect lanyard are ok...
Crockett is offline   Reply With Quote
Old 06-06-2015, 12:00 AM   #15
ColoradoRick's Avatar
x2
I've seen some attach it to the hitch ball but I don't like that idea.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 06-06-2015, 01:00 AM   #16
Just a member
kandl's Avatar
Originally Posted by LairdT View Post
I have been hooking up my TT breakaway cable a variety of ways with little thought as to how effective they might be. Does anyone have a fast means (clips, chain links, looping system, etc) that is both fast and guarantees the brakes will engage if necessary? Our 2015 Nitro XLR is our third TT and every dealer has demonstrated a different method, none of which seem to be well thought out! Gotta be an "Engineered" approach somewhere!
It's fast, untested and there are no guarantees in life.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-18-2015, 03:12 AM   #17
Quick link to the hook where safety chains attach. If the hitch falls out of receiver for some ungodly reason, my trailer breaks should engage. If the entire hitch assembly attached to the frame fell off I guess I would be up the creek without paddles.
vanreever is offline   Reply With Quote
Old 08-18-2015, 05:24 AM   #18
340_Formula_S's Avatar
If you run your cable through your safety chain and hook at the same point, make sure the cable will fully extend and pull the pin before the chain gets tight.
Elko, Va.
2012 Ram 3500 DRW Cummins High Output
2012 Cedar Creek 36B2
340_Formula_S is offline   Reply With Quote
Old 08-18-2015, 07:22 AM   #19
Elko, Va.
Good point. Mine is close. Have to investigate...
