Old 02-18-2014, 08:41 PM   #11
caper's Avatar
Any idea how to get broken handles off dump valves? Mine broke last fall while winterizing. Only 1 side of the handle, not both. Still operable, but would like to get fixed before the other half breaks.
The handles just screw off. You can purchase metal handles to replace the plastic handles now on the trailer. I replaced all three on my unit last year.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-18-2014, 08:54 PM   #12
phat phrog stunt crew
Sweet. Thanks caper. I did not want to have to replace entire valve just to get some plastic handles. Will try etrailer or local dealer.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 02-18-2014, 09:11 PM   #13
caper's Avatar
I would replace the plastic with metal handles.
Terry and Janet
2007 Ford F150
Old 02-20-2014, 05:52 PM   #14
Explorer
maybe
I have never seen a set up like this, my guess on the first valve on the black water is do to the long-ish pipe run. It probably prevents solids from building up and plugging the pipe run. As for the second valve, on the same line, it is part of a standard set up and probably easer to install an extra than create something new.
Any chance you bought this camper used and the former owner installed the extra valve?
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
black
