Old 07-18-2016, 12:38 PM   #11
lmiken's Avatar
I have had 2 of the plastic valves go bad (did not let any water go through). One RV repair place gave me a 90 degree connector saying they do not sell the valves any more, they just get rid of them. They said they have seen too many failures (which usually flooded the trailer and caused a lot of damage). They said I was lucky it failed closed. I have since gotten a brass valve which seems to work better. Get a 90 degree connector to see if the valve is the issue.
2015 Flagstaff 32IKBS
2008 F350 6.4
1999 Palomino Filly Popup (my daughter's now)
lmiken is offline   Reply With Quote
Old 07-18-2016, 02:40 PM   #12
WolfWhistle's Avatar
Originally Posted by jtstromsburg View Post
Not too uncommon to find the check valve installed backwards. I know you said you just changed that but might not hurt to make sure.
It's about gotta be that or the whole hose is plugged at the spray end. In which case case you'll have to gain access to where it attaches to the tank.
X2 on the backwards statement ... several XLR guys on the forum have found the check valve backwards from the factory. Mine was making all kinds of noise and preventing good water flow, so mine went bye-bye... what do you need a check valve on a black tank flush for anyway? It would take two failures at once to possibly cause a black flow situation. And, you would be not following instructions (whatever the heck they are!)
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 07-18-2016, 06:05 PM   #13
may I ask a question related to this? As I was flushing my black tank the other day I had a thought. is there a back flow preventer built in or am I chancing that I am polluting my fresh hose supply. I am hooked up to water supply with my fresh hose and then I am running a garden hose off the same spigot ( a tee) and this to the black tank flush. or should I be buying something to prevent this? thanks
Drrayrn is offline   Reply With Quote
Old 07-18-2016, 07:00 PM   #14
There is a back flow preventer on the vacuum break
atcbrownie is offline   Reply With Quote
Old 07-18-2016, 07:31 PM   #15
thanks for the come back. now I can breath, or I mean, drink better
Old 07-18-2016, 07:44 PM   #16
RSchleder's Avatar
To ensure you can always breath, buy a second hose (different color is best) and use it exclusively for your back flush process!
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 07-18-2016, 07:57 PM   #17
Witch Doctor's Avatar
I agree with this but remember if your water pressure is 45 PSI positive side it's not going to contaminate your hose. Also you should be leaving your valve open when in use by the directions. So no back flow through your hose but it's always best to use to different hoses... PS: but I also use bottle water not nothing from my hose.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-18-2016, 08:51 PM   #18
mekkerlc's Avatar
Is it normal for the backflow preventer (i assume that's what is up under the bathroom sink??) for my black tank flushes to make loud vibrating noise when in use?
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
mekkerlc is offline   Reply With Quote
Old 07-18-2016, 09:19 PM   #19
HONDAMAN174's Avatar
Black tank flush not working
I had a problem once which was I had my pressure regulator connected while trying to flush tank. Very little water was going to tank. Took off regulator and problem solved. Must have built up more than 55psi and shut down the flow. Regulator had worked fine all weekend and all camping trips since.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 07-18-2016, 10:28 PM   #20
This was my experience with the black tank flush...I hooked up the hose to the exterior connection. Turned the water on. After a while I opened the sewer hose to drain the blank tank. Nothing. I wondered where all the water went. Looked in side the RV and saw water running out from the sink cabinet. Cleaned that mess up and looked for answers. It was suggested that I bang on the vacuum breaker. I gave it several good hits with a wrench. I also hooked up my air compressor to the black tank flush exterior connection and let the air pressure blow out any obstructions. Hooked water hose to the flush connection again and voila...success. It works now. This may or may not work for you. Just letting you know what I did.
GMax is offline   Reply With Quote
black, black tank, black tank flush, tank
