Old 07-17-2016, 07:59 PM   #1
Black tank flush not working
Hey guys,
My black tank flush has not been working for the last two camping trips. I just finished replacing the vacuum breaker and check valve and there is still no change.
This is what happens. When I turn on the water for the black tank flush you can hear the water line build pressure for about a second and then nothing happens.
Does anyone have any suggestions as to what to do next?
2015 Salem hemisphere 312qbud
Jason
atcbrownie is offline   Reply With Quote
Old 07-17-2016, 08:26 PM   #2
Last campground I was at had really low pressure on the hose at the dump station. My black tank wouldn't flush so I flushed it when I got home and it worked fine.
2016 Coachmen Apex 288BHS
2015 F150 Sport 4x4 3.5 Eco Boost
4B11T is online now   Reply With Quote
Old 07-17-2016, 08:39 PM   #3
I have tried two campgrounds that it previously worked at and have tried at home as well. I don't think it is a pressure issue.
Old 07-17-2016, 10:46 PM   #4
jtstromsburg's Avatar
Not too uncommon to find the check valve installed backwards. I know you said you just changed that but might not hurt to make sure.
It's about gotta be that or the whole hose is plugged at the spray end. In which case case you'll have to gain access to where it attaches to the tank.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 07-17-2016, 10:52 PM   #5
Platokidd's Avatar
Location: Home of the 2016 WORLD SERIES CHAMPIONS CHICAGO CUBS
Did you check the screen on the hose connection?
2014 LaCrosse 323RST-TE-C
2009 CHEVY 2500HD Silverado Z71
2016- 92 nights of camping
Platokidd is online now   Reply With Quote
Old 07-18-2016, 04:16 AM   #6
Yep the screen is perfect
Old 07-18-2016, 05:41 AM   #7
Witch Doctor's Avatar
X'2 the only thing it really could be, unless your hose collapsed or kinked somewhere. They have alot of extra hose on those flush systems.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-18-2016, 05:46 AM   #8
Amen to Extra Hose! ^^ Youroo!!
ID:	114467   Click image for larger version
Old 07-18-2016, 06:35 AM   #9
The nice thing about the location of the vacuum break is that it is right where the tank flush connection is. It is definitely installed the correct direction. I guess it must be a kink in the hose. I will play around with the hose later today to see if I can wiggle the hose enough to make it work
Old 07-18-2016, 01:22 PM   #10
ccsvolsfan's Avatar
There is a USB snake camera on Amazon for less than $25. About 10 feet long and has led lights. Would be great for looking in those hard to reach areas when a problem arises.
ccsvolsfan is offline   Reply With Quote
black, black tank, black tank flush, tank
