Old 10-06-2016, 08:42 AM   #1
Elkhounds's Avatar
Blue Streak Users
So this has been our first year using Blue Streak. Do I have to pull it out and clear the line when winterizing? I know it does not take much to do but if it is ok to leave I'll leave it. If not I'll pull it.
2015 F-350 Platinum 6.7 PowerStroke
2017 Columbus 320RS
Andersen Ultimate Aluminum hitch
18,900 miles of RV'ing since May 2014
Elkhounds is offline   Reply With Quote
Old 10-06-2016, 08:46 AM   #2
No. leave it in place. The liquid will get slushy but will not freeze.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
Old 10-06-2016, 08:49 AM   #3
bubbles's Avatar
This is what one member posted awhile back saying it was from Blue Streak:
"The chemical freezes at zero, not 32 degrees and it not a hard freeze. With the tank and lines being plastic you don't have to remove the chemical for the winter.
Just winterize your coach, like you would normally".
Old 10-06-2016, 08:56 AM   #4
TURBS's Avatar
I've never did anything with mine for winter
Old 10-06-2016, 10:04 AM   #5
Elkhounds's Avatar
Well that was easy. Thanks everyone. I'll leave it in place and do my winterize as normal. Going to be a sad weekend.
2017 Columbus 320RS
