what RECEIVER do you have? If it has a 'TV OUT' on the back, you can run that to an additional TV to view the same thing that you are viewing on the main TV, which gets it's feed via the HDMI out from the receiver. The second TV will only see channels in SD, though, but you can even use a splitter to send that same signal to another tv, etc, or even send the additional signal to your 'box of many buttons' input to watch it on other TVs... you'll have to change the channels, though, from the Main receiver, wherever it sits.
for portable antennas with dual outputs, such as our KingTailgater2, you can send the signal to both a MAIN receiver, and a SECONDARY receiver.
The Main can see all the channels from all the satellites, but the Secondary will only see channels from the satellite the Main was tuned to at the time you went thru the 'acquire satellites' setup on the secondary.
A little confusing, but the HD channels are in HD for both, and the secondary can still switch 'channels', just not satellites.
The Turners...
