Old 08-29-2016, 08:00 AM   #51
Wolverine 1945's Avatar
Originally Posted by lugoismad View Post
I have a sewer clean out pipe that is y'd off my sewer line in my backyard.
Can I drain my tanks into that, if we boondock with no dump facilities?
There are some free dump stations around,,,
You may want to Google it,,, can't remember the Web Site ???
Wolverine 1945 is online now   Reply With Quote
Old 08-29-2016, 08:35 AM   #52
Herk7769's Avatar
My vent drops directly to the trap. I know because I have had to have it "plunged" when we first moved in. The previous owner did not have a cap on the stand pipe and grass clippings must have been falling in for years.
Plunging it with a long iron pipe with a circle of rubber and water to make the seal cleared the trap. Never had a problem since (25 years) and have been using it as a dump station for about 5 years now.
HAM CALLSIGN - KC3FFW
Old 08-29-2016, 08:43 AM   #53
W5CI's Avatar
Originally Posted by Wolverine 1945 View Post
If you ask,,, they will tell you NO !!!
Don't Ask and Don't Tell
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank
Amateur Radio W5CI 2016 Days Camping 50
2017 Days Camping 31
W5CI is offline   Reply With Quote
Old 08-29-2016, 08:50 AM   #54
Originally Posted by ccsvolsfan View Post
OMG, the sewer police on here are worse than the weight police, just dump it.
No kidding!
Sometimes I think we are listening to government employees discussing these topics...
325BH is offline   Reply With Quote
Old 08-29-2016, 08:56 AM   #55
dcheatwood's Avatar
Whats the difference in dumping in you clean out and flushing your home toilet another 50 times?
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 08-29-2016, 08:56 AM   #56
Originally Posted by 325BH View Post
No kidding! Sometimes I think we are listening to government employees discussing these topics...
Absolutely mind boggling.
Old 08-29-2016, 09:26 AM   #57
NMWildcat's Avatar
No kidding!
LOL!!!! That's just what I was thinking. Makes me glad I'm in the southwest where we don't have so many rules about every little thing. And if we do have goofy rules there is nobody to enforce them and we sure don't call to ask if we can do something logical
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-29-2016, 09:40 AM   #58
Seams like now days rules & laws are only for people that want to follow them !!!
Old 08-29-2016, 09:47 AM   #59
Originally Posted by BandJCarm View Post
Well..........we have one at home too. Just had it pumped out 3 months ago.
The only 4" pvc pipe is the air vent. To get to the actual tank, you have to dig out the entire concrete top, with two big eye bolts in it, and lift it totally out. There's no access that I know of other than that.
https://www.google.com/search?q=what...eRcRc7lS4nM%3A
A person would have to cut into the line between the house and the holding tank. It can not go between the tank and the field system. The 4" pipe would be buried approx. 18" below the surface. Because the buried pipe is rigid, you would have to dig a hole wide enough to cut the pipe in two places in order to fit a short length of pipe to each end of the Y connection having the drain port, then use a rubber coupler sleeve at each end, and secure them with 4 stainless steel hose clamps. Provided the original excavation has had time to settle, washing the dirt in with a garden hose around the new fitting will settle the dirt under the connection and it will stay in place. The connection should stand the test of time.
PenJoe is online now   Reply With Quote
Old 08-29-2016, 09:56 AM   #60
NMWildcat's Avatar
And you can also make the argument that are too many rules and laws that make absolutely no sense at all😁
drain, tank
