Old 08-29-2016, 10:05 AM   #61
Wolverine 1945's Avatar
Originally Posted by NMWildcat View Post
And you can also make the argument that are too many rules and laws that make absolutely no sense at all��
VERY True !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-29-2016, 10:13 AM   #62
BandJCarm's Avatar
Originally Posted by PenJoe View Post
A person would have to cut into the line between the house and the holding tank. It can not go between the tank and the field system. The 4" pipe would be buried approx. 18" below the surface. Because the buried pipe is rigid, you would have to dig a hole wide enough to cut the pipe in two places in order to fit a short length of pipe to each end of the Y connection having the drain port, then use a rubber coupler sleeve at each end, and secure them with 4 stainless steel hose clamps. Provided the original excavation has had time to settle, washing the dirt in with a garden hose around the new fitting will settle the dirt under the connection and it will stay in place. The connection should stand the test of time.
Yep. And thanks!!!
The better 1/10 of my brain is sort of saying "That woulda been a good idea if you'd had them do it originally, but now........just haul it somewhere and pay to dump it!".............
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 08-29-2016, 10:32 AM   #63
Originally Posted by BandJCarm View Post
Yep. And thanks!!!
Or search for Free Dumpsite !!!
Old 08-29-2016, 11:57 AM   #64
head gamez's Avatar
X2. WAY too much over thinking here😉
Seems to be common theme in most topics... Ball grease comes to mind!
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 08-29-2016, 02:01 PM   #65
Witch Doctor's Avatar
Originally Posted by dcheatwood View Post
Whats the difference in dumping in you clean out and flushing your home toilet another 50 times?
The reason is just what I stated for one, I know your smart enough to know the difference in Volume at one time, Flush your toilet it's probably 1.75 or 2 gals max, dump your holding tank full the pure volume of 40 gals at once could damage the system, in older Towns that the systems are old tar or clay layered pipe. Do I agree with my Towns Ordinance NO, but just don't get caught depending on your Town or City Policy. Do we have sewer police? NO, but I do have noise neighbors that will call if they see you, there thinking is why do they have to pay a higher tax rate because of repairs when they don't do it because a person is to lazy to go find a dump station at the sewer plant or the many other places around. Not all people think like campers...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-29-2016, 02:08 PM   #66
I've been doing it for years, just make sure you use a seal around the cleanout to keep orders from escaping into your neighbors yard and don't get careless..
In my case I have a 40' run between my TT pad and the cleanout so I purchased a macerator and fifty foot of hose. Work great and cleanup is a breeze.
Las Cruces is offline   Reply With Quote
Old 08-29-2016, 02:24 PM   #67
dcheatwood's Avatar
Witchdoctor, I got you now. I didn't catch the volume issue. Makes sense.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 08-29-2016, 02:26 PM   #68
waiter21's Avatar
Its easier to ask for forgiveness than it is permission.......
Open the clean out port, hook up your hose, and open the valve. If anybody asks what your doing tell them your flushing your toilet...
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-29-2016, 03:19 PM   #69
BandJCarm's Avatar
Search turned up nothing.
But found several that are cheap, that's good enough.
FROG AR-0019-242
Old 08-30-2016, 07:32 AM   #70
I do not remember for sure what we Goggled,,, maybe one of the others will remember ? There is also a smart phone app showing all Sanitation Dump Stations,,, not just the free ones !!! I saw c CG a while back where the Dump Station was out side the park ??? There are a lot of $5 & $10 places to dump,,, I hear some States even have them @ rest stops ????
drain, tank
