Old 08-27-2016, 02:17 PM   #1
Can I drain my tanks into my sewer clean out at home?
I have a sewer clean out pipe that is y'd off my sewer line in my backyard.
Can I drain my tanks into that, if we boondock with no dump facilities?
lugoismad is offline   Reply With Quote
Old 08-27-2016, 02:20 PM   #2
Witch Doctor's Avatar
Sure you can, but I would check with your town first. Unless it's a septic system. I know in my Town if you get caught dumping into the Town sewer it's a big fine...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-27-2016, 02:21 PM   #3
Head Rambler
Yes you can do that. A lot of people use the cleanout to dump in situations where they've boondocked with no dumping facilities.
If you're on a public sewer you may want to check with utility to make sure they're ok with it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-27-2016, 02:25 PM   #4
Cool, thanks. I'll ask, it's a public sewer.
Old 08-28-2016, 02:27 PM   #5
padcarroll
Many places do not meter the amount of sewage that you dispose of. Instead they bill you by a percentage of the amount of your water usage. If this is the case the locals will probably tell you you can't dump into the sewer. If the cleanout is in the backyard, who would know?
Dave and Pam Carroll
Callie - 8 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
padcarroll is offline   Reply With Quote
Old 08-28-2016, 02:45 PM   #6
CaptnJohn's Avatar
Agree. I'd rely on forgiveness before being told no.
Old 08-28-2016, 02:52 PM   #7
padcarroll
Besides, if you were sitting (pun intended) at home, wouldn't you be useing the sewer line anyway?
Old 08-28-2016, 03:04 PM   #8
Just use it, don't ask for permission. It's not like your bringing someone else's waste water home and dumping it into the sewer. If you were home instead of camping you would be using the sewer system and truth be known you probably dump more when you are camping than not dump. It seems to me the city owes you
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-28-2016, 03:05 PM   #9
Most sewer is metered by the amount of water you use but if its your sewer on your prop. it is yours to use. You dont get a discount if you water your garden, lawn or flowers unless you have a seperate sprickler meter.
markb422 is offline   Reply With Quote
Old 08-28-2016, 03:08 PM   #10
Flybob's Avatar
If your sewer bill is based on your water usage, then you have not paid for something you did not use and you may get a no. If that is the case, tell them you filled your water tank at home so the usage was metered.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
drain, tank
