Originally Posted by ependydad
Is that a Companion that goes to the Turnoverball Gooseneck?
I can't pull the handle to the gooseneck pin unless I loosen the draw down bolt. Are you able to loosen that? Or don't you need to?
Yep, that's correct. I have to loosen the draw down bold before I'm able to do this but that's not a hard process.
To reinstall I just back the truck back under it and lower back into the turnover ball hitch. It was odd the first few times but can do it fairly easily now.
