So take your battery with you, hook it up, run the genny and do what you want to do, then unhoook the battery and take it home with you. No matter how far below 0 it might be the battery will be fine because of the charge going into it from the converted. The main issue with running shore power with no battery is if you fail to ensure the battery cables are not touching in the battery box. If they are it will act as a dead short and burn out the converter.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
