Old 12-24-2014, 05:43 PM   #21
I say retire and turn off the cell phone.
Johnv is offline   Reply With Quote
Old 03-18-2015, 09:24 AM   #22
Spikedog's Avatar
Originally Posted by codytaylor1624 View Post
I have never dealt withUniden before but their packages seem to be a direct competitor to Wilson. I can say for Wilson that their customer service is second to none. My first one was damaged on arrival and called them and they sent me the next level up booster for free just for the hassle.. I will be a Wilson fan for life if for nothing more than their customer service..
And yes I purchased my outside antenna separately. If you have done any research at all you know that there is 2 basic types of outdoor antenna. Yagi and Omnidirectional. I went with the omni directional to sacrifice just a little performance to gain some asthetics as well as simplicity. I did not want to have to adjust the antenna every time I moved. The Yagi does work better but it requires adjustment every time you move the trailer if you want the best perf. I mounted my outdoor antenna to the old air cable antenna so that I can crank it up if needed to gain some extra distance between antennas.. That also has the added benefit of already having coax ran along the inside of the roof and coming out in the very back by the TV.
Again let me know if you have any questions and I can show you my setup! Its pretty clean!
I just bought a Uniden UM-50 kit, and was planning on using the existing crank-up TV antenna as the outside antenna. I bought an adapter so I can hook up the SMA to F connector (coax cable) so the connections will match up.
However, talking to the Wilson company, they said the frequency of the cell phone signal doesn't match the old TV broadcast signal, so I'd be better off with the tiny antenna provided in the kit. Talking with a ham radio expert at work, he mentioned it's more of a problem with the antenna transmitting than receiving. I thought it was a win-win with the antenna and cable already run and a hole punched in the RV roof; plus, the antenna has a power switch so it should get an additional boost.
I don't know which antenna will work better until I get out in the boonies, but I thought it was food for thought.
2007 Coachman Freelander 26' w/ E-450 6.0L diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
Spikedog is offline   Reply With Quote
Old 03-18-2015, 12:19 PM   #23
Kaadk's Avatar
Your Ham Radio friend was right, the issue is with transmitting. Specifically, using an antenna that's not designed for it won't transmit all the power going to it. That unused power returns back into the transmitter, and potentially damages the equipment. I wouldn't recommend trying it.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 03-18-2015, 12:34 PM   #24
extremebike's Avatar
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is online now   Reply With Quote
Old 03-18-2015, 12:44 PM   #25
Spikedog's Avatar
Thanks for the logical reply. So maybe what the other guy (codytaylor1624) was doing was using only the original antenna's coax cable while using the provided antenna. My new antenna has a magnetic base that won't stick anywhere on my RV, but I suppose I could get it to stay put on the roof somehow.
Old 03-18-2015, 12:47 PM   #26
B and B's Avatar
Spike, i stuck my Sirius antenna on with a dollop of RV roof sealant. Works well, it is on my entertainment slide and lives inside when the slide is retracted.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-18-2015, 12:52 PM   #27
BamaBob's Avatar
The WeBoost drive 4G Cell Phone booster simply *works* However, it works at a cost - literally! Cheapest I have seen on is on Amazon for $379
But if work depends on cell connection it may be worth it to you.
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 03-18-2015, 01:12 PM   #28
Kaadk's Avatar
At that price that better be a cell-to-sat phone converter.
Old 03-18-2015, 01:32 PM   #29
BamaBob's Avatar
X2
Sorta like the WiFiRanger WIFI Booster ($600 for the setup )
Definitely Cadillac products!
Old 03-18-2015, 04:04 PM   #30
Spikedog's Avatar
Oh, none of these cell phone boosters are cheap. I got the Uniden 4G setup for $425. The 3G kits are maybe $100 cheaper. At least I can use this thing in my car too; powered off the cigarette lighter.
