Old 03-11-2015, 09:57 PM   #1
bigdog 616's Avatar
Changing a tire on my travel trailer leave spring suspension 26 inch tires tandem
Has anyone used the Anderson rapid Jack
Sent from my iPad AIR using Forest River Forums
bigdog 616 is offline   Reply With Quote
Old 03-12-2015, 12:31 AM   #2
Crockett's Avatar
i see no one is responding. I have not personally. my neighbor has one and claims it works great. I could get the particulars for you if you have questions..
Crockett is offline   Reply With Quote
Old 03-12-2015, 01:27 AM   #3
Hi I have have just put a 4x6 with a 2x4 in front of it to ramp the good tire up on to the 4x6 . This will raise the flat tire off the ground.
Make sure you loosen the lug nuts on the flat tire before you raise it off the ground.
This will not work if you have the Dexter torsion axle.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 03-12-2015, 07:33 AM   #4
bigdog 616's Avatar
Changing a tire on my travel trailer leave spring suspension 26 inch tires ta...
I have tried using trailer aid ramp that product did not work my trailer would not lift opposite tire off the ground complete useless junk
Old 03-12-2015, 08:47 AM   #5
DDC
DDC's Avatar
I have one of these and it works well, Trailer Aid Plus Tandem Tire Changing Ramp, got it from Amazon use it for doing maintenance as well like greasing bearings or checking brakes. There are two sizes of this one and I have the highest lift.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 03-12-2015, 07:53 PM   #6
bigdog 616's Avatar
I have tried that trailer aid plus does not work on my trailer waste of money for me
Old 03-12-2015, 08:02 PM   #7
gashog's Avatar
I just bought a Rapid Jack a few weeks ago. I'm hoping to try it out this weekend to see if it lifts the adjacent tire off the ground. Worse case would be having to put a board under the rapid jack to get the necessary lift. I have read that some suspensions require adding a board. We'll see and hope for the best.
edited:
I have the Torsion Axle, Rubber-Ryde Suspension, I will wait until I get a response back from Dexter on using my rapid jack.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 03-13-2015, 06:50 PM   #8
gashog's Avatar
Here's my answer from Dexter.
Dexter would not recommend using drive up ramps to support the weight of the
trailer on one axle or one wheel. The trailer weight should be lifted from
the frame to avoid damaging the suspension.
Jim Miller / Dexter Axle
Now the decision, sell my just purchased Andersen Rapid Jack or use it????
Old 03-13-2015, 07:18 PM   #9
Flybob's Avatar
Here is the answer I received from my dealer. LMAO
Per the Manufacturer, they don't recommend that the customer change tires. In the case of an emergency, a tire company/specialist would be the best qualified person to perform the repair.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-13-2015, 07:33 PM   #10
gashog's Avatar
I just went through my Forest River GENERIC Owners Manual. It has ZERO information on jacking. Looks like my my Windjammer is just going to sit parked until I get this figured out. I won't depend on a call to a specialist to change a tire...if he throws a floor jack under it and it's wrong, the results from his mistake won't be know right away and I'm stuck with the repairs....
suspension, tire, tires, trailer, travel, travel trailer
