07-07-2017, 02:56 PM
Cleaner needed for Faded Skylight
Anyone know what cleans this? I was going to order a new one in Smoke/Clear since I want to reseal the Skylight fixture anyway, but thought I could try cleaning it first?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
07-07-2017, 03:00 PM
If it is oxidized like a headlamp cover on an auto then try one of those headlight restoration kits from the auto store. Personally I would just go for a new one in smoke... and consider Eternabond tape along with caulk...
2014 Shamrock 183
07-07-2017, 03:06 PM
I am thinking it will be brittle if I clean it and the smoke won't get so ugly as this clear one after a few years. I will just use Lap sealant to seal this Etrnabond is great but save that in case I need to do an emergency repair ...
07-07-2017, 07:30 PM
I cleaned ours with toothpaste in lieu of headlight restoration kit (you tube) followed up with lite coat WD40 (you tube). A lot clearer, then had to clean inside as well.
2015 Tracer 3140RSD Touring
2016 Nissan Titan XD Diesel
Blue Ox Swaypro BXW1500
07-07-2017, 08:03 PM
I will have to try that, but I think I may just order a new one. I have spent a lot of time fixing and cleaning this unit so for $83.00 I would hate to be cheap to make the unit look better and let a little more light in, but trying the toothpaste trick is a cheap easy way to see if it works a little then I can replace mine in the fall.
07-09-2017, 04:48 AM
I cleaned ours with Rubbing Alcohol,,,then one coat of Adhesive primer,,, and then applied about 3 coats of White paint !!!
Yes I am a Skylight Hater !!!
07-09-2017, 08:37 AM
I like the light coming thru over the shower so I would go for a smoked one to replace the clear one that turned yellow. I stay on top of this trailer the original owner didn't do anything so I am playing catchup with Maintenance and just keeping things in clean and in working order.
07-09-2017, 08:47 AM
How about painting it in leiu of trying to clean it?
07-13-2017, 06:00 AM
It must be cleaned first,,, then use the proper primer,,,
or the paint will end up on the ground !!!
07-13-2017, 09:33 AM
Not going to paint, If I can't get it clean will replace with a smoke colored cover instead, I just hate when clear or white parts tinge yellow, replaced my Hood/Stove vent bc it was yelllow, new one is brute white
08-17-2017, 07:25 PM
Attachment 143896
https://www.walmart.com/ip/Meguiar-s...olish/16550253
WORKS using a rag or a buffer!
08-17-2017, 07:27 PM
Originally Posted by l001952119
X2
08-18-2017, 09:03 AM
Originally Posted by Rock W
SD20 is a hell of a cleaner,,, I get it from our local RV dealership !!!
08-18-2017, 09:10 AM
Originally Posted by mbbutler
X2
yes yes yes
12-11-2017, 12:06 AM
Toothpaste
12-11-2017, 10:50 AM
Paint thinner - Primer & about 4 coats of white paint !!!
Nomo cleaning needed !!!
12-11-2017, 11:09 AM
Usually, when those oem (read thin and cheap) skylights turn that color, it's just a matter of time until they crack. Mine usually last 5 years in our sun before I replace them with smoke colored ones that are about three times thicker.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
12-11-2017, 11:42 AM
Georgia Rally Coordinator
Using 303 makes a big difference in how long they will last. My last camper was 5 years old when I traded and the sky lights where still in great shape covering when not in use helps also which I do during winter months. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
12-11-2017, 11:46 AM
Ah, never thought of using 303 on the skylight! I just replaced mine, so I'll give it a shot. We never cover ours as we use year round. Do wish I had covered parking though!
